Cisco SD-WAN 20.12 - create own SD-WAN lab from scratch?
GlenGTR
Hi all and apologies in advance if this topic has been covered here already (at least I couldnt find it) but I am working on the Cisco SD-WAN 20.12 and wanted to see if its possible to create my own SD-WAN lab from scratch?
Ie - spinning up fresh vManager, vBond and vSmart Controllers etc.
I tried to create a vManager via the "Manager" node but after I had followed the startup prompts (selecting the persona, formatting sdb 256 GB harddrive) the disk space within CML eventually goes all the way up to 100%.
Thanks in advance for any help / info that you guys can give!
@GlenGTR you are correct there are a couple of sd-wan options, always on (ready only), reservation (admin access) both you cannot add anything else. However if you use the CML sandbox you can build your sd-wan fabric from scratch.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thanks for the reply @bigevilbeard. I'm still quite new to the CML lab and SD-WAN, are you able to tell me how I can create my vManage controller from scratch within CML? I think the way I was trying was wrong
There is a guide here. https://developer.cisco.com/docs/modeling-labs/2-7/cml-release-notes/ the sandbox might have the images already loaded in, so you could skip a a few steps, unless you want a newer image.
Hope this helps.
balaji.bandi
I have tried bit lower version in the Lab, works as expected :
https://www.balajibandi.com/?p=2028
CML i don't see any issue i guess it should be straight forward :
https://www.youtube.com/watch?v=WxiZ5bxlDk8
I will test later on CML 2.7 and let you know if come across any issue.
BB
This video provides an overview how to create your own Cisco Catalyst SD-WAN Virtual Lab using free SD-WAN Lab Deployment Tool in Cisco Modeling Lab (CML). Overview TechNote: https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/222057-sd-wan-lab-deployment-tool-for-cisco-mod.html Free Cisco ...
