08-15-2020 12:37 PM
Learning Labs on developer.cisco.com - connectivity issue.
I am trying to use developer.cisco sandbox to learn NSO.
I received separate VPN credentials for the same.
When I connect to the VPN, I cannot even connect to the learning labs to refer to the documents.
I saw a note that connecting to internet is disabled for the VPN. However, it should be able to connect to developer.cisco.com.
08-16-2020 04:43 PM
08-16-2020 09:35 PM
Thank you for your quick response.
Yes, I received a mail saying that the lab is ready and I am able to access the lab.
But I am not able to access the developer.cisco.com site to refer to documents/tutorials or the Lab GUI while connected to the VPN provided in the mail.
I have attached the screenshots and links.
Thanks!
https://developer.cisco.com/learning/lab/learn-nso-the-easy-way/step/2
08-17-2020 02:41 AM
You should be able to access the internet whilst on the anyconnect sandbox VPN, check your DNS/AC settings. The VPN is set up for split tunnel. I have seen this with a few users on Windows.
Hope this help.
