Bookmark
Subscribe
2428
IOS XE on CSR Recommended Code AlwaysOn - Connection Reset by peer
barweiss
Just a heads up :), I was doing some yang testing this morning on sandbox-iosxe-recomm-1.cisco.com. Unable to connect via ssh on port 22 and get:
kex_exchange_identification: read: Connection reset by peer
Also NETCONF attempts fail as well, here is the error (I was running a demo scipt from https://github.com/CiscoDevNet/netprog_basics/network_device_apis/yang/example.py :
ConnectionResetError: [Errno 54] Connection reset by peer
Thanks!
Barry
@barweiss all good now
(venv)root$ ssh developer@sandbox-iosxe-recomm-1.cisco.com
The authenticity of host 'sandbox-iosxe-recomm-1.cisco.com (131.226.217.149)' can't be established.
RSA key fingerprint is SHA256:OTn7AsY0B89fZpELzwz1xxDOoqX9PskSRvD5gEUD5F0.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added 'sandbox-iosxe-recomm-1.cisco.com,131.226.217.149' (RSA) to the list of known hosts.
Password:
Welcome to the DevNet Sandbox for CSR1000v and IOS XE
The following programmability features are already enabled:
  - NETCONF
  - RESTCONF
Thanks for stopping by.
csr1000v-1#
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
10 Replies 10
Thanks @barweiss  ENG is aware.
Password:
  - NETCONF
  - RESTCONF
csr1000v-1#
Awesome, all good now too! Thanks  @bigevilbeard !
jeff.hoare
It appears to not be working again.
sean.hutcherson
IOS XE on Catalyst Always On : sandbox-iosxe-latest-1.cisco.com is returning kex_exchange_identification: read: Connection reset by peer Connection reset by 131.226.217.143 port 22
What is the fix for this?
@sean.hutcherson This error typically points to a network connectivity or version compatibility issue. Cisco team will need to look into this to fix.
Hope this helps.
seitjan0319
I also have connection issue kex_exchange_identification: read: Connection timed out
Alexander Stevenson
The team is working on this.
sean.hutcherson
FYI:  The device is now accessible but the password credential is not working.
https://devnetsandbox.cisco.com/RM/Diagram/Index/7b4d4209-a17c-4bc3-9b38-f15184e53a94?diagramType=Topology
  • Cat8000V Host: sandbox-iosxe-latest-1.cisco.com
    • SSH Port: 22
    • NETCONF Port: 830
    • gRPC Telemetry Port: 57500
    • RESTCONF Port: 443 (HTTPS)
  • Username: admin
  • Password: C1sco12345
Alexander Stevenson
If the 'Latest Code' always on sandbox has issues, please try the alternate, the 'Recommended Code' one:
https://devnetsandbox.cisco.com/RM/Diagram/Index/27d9747a-db48-4565-8d44-df318fce37ad?diagramType=Topology
* CSR1000V Host: sandbox-iosxe-recomm-1.cisco.com
* SSH Port: 22
* NETCONF Port: 830
* RESTCONF Ports: 443 (HTTPS)
* Username: developer
* Password: lastorangerestoreball8876
**There is also a reserve IOS XE sandbox in the catalog.
