07-21-2021 07:10 PM
I am running through this lab "Exploring IOS XE YANG Data Models with NETCONF"
when I try this command to ssh to the CSR1000V Host (sandbox-iosxe-recomm-1.cisco.com),
ssh -oHostKeyAlgorithms=+ssh-dss developer@sandbox-iosxe-recomm-1.cisco.com -p 830 -s netconf
The response is always:
kex_exchange_identification: read: Connection reset by peer
Is there anything wrong with my command?
07-21-2021 11:14 PM
Ok, I try this host CSR1000v Host: sandbox-iosxe-latest-1.cisco.com and it works.
07-22-2021 02:59 AM
@EvanC you command is correct - i am unsure why there is such difference between the two XE device, i saw the same with REST also.
07-22-2021 05:20 AM
There's something definitely wrong with the lab. The host does not answer on ssh protocol, accessing it on https protocol gives nginx error "gateway timeout".
Cisco, please check the CSR.
07-22-2021 07:35 AM
@mschedrin i have checked this as of time 2:35 PM Thursday, July 22, 2021 Coordinated Universal Time (UTC) via ssh.
(venv) STUACLAR-M-R6EU:~ stuaclar$ ssh developer@sandbox-iosxe-recomm-1.cisco.com Password: Welcome to the DevNet Sandbox for CSR1000v and IOS XE The following programmability features are already enabled: - NETCONF - RESTCONF Thanks for stopping by. csr1000v-1#
07-22-2021 08:10 AM
Right, ssh and netconf works now, however webinterface and restconf on port 443 still reply "502 Bad Gateway
nginx/1.13.12". I guess it's not supposed to be like that.
07-22-2021 09:16 AM
@mschedrin as noted above this version is showing issues when using RESTCONF. Recommend to use https://devnetsandbox.cisco.com/RM/Diagram/Index/7b4d4209-a17c-4bc3-9b38-f15184e53a94?diagramType=Topology
Hope this helps.
