Open NX-OS nexus01 access issue
artiko
from yesterday when i reserve the SandBox in subjcet i cannot reach in SSH the first N9kv (nx-osv9000-1: 172.16.30.101); i can access the other three.
From the VIRL console the node i ACTIVE.
It's an issue of the sandbox or can i do somethings?
thanks
fabio
artiko
In case someone has the same issue ... from the virl console, reacheble in http, you can stop/start the node and check the interface status. From here i reboot the node-1 and now is working.
artiko
If you jump into the devbox, you can do this via virlutils also. The cmd 'virl nodes' will show your devices, whichever is not playing nice just issue 'virl stop [device name]' then 'virl start [device name]'
Hope that helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
