PCCE 11.5 rogger connection failed.
frzhang
"The trust relationship between this workstation and the primary domain failed"
Tried from my PC and domain controller (yes, I can get on domain controller) in the PCCE lab. Result the same.
Thanks.
crnewman
Level 5
Level 5
Hi Frzhang,
I was able to remove and re-add the Rogger to the domain.  Your problem should now be resolved, but you will need to start a new reservation for the change to take effect.
Craig
crnewman
Level 5
Level 5
Hi Frzhang,
We recently did some maintenance on this lab.  I'll take a look and let you know the result.  You may need to restart your reservation once the issue is resolved.
Craig
crnewman
Level 5
Level 5
Hi Frzhang,
Craig
Thanks.
