sandbox issue
Mohamed Atallah
There was an error processing your request
where is this issue came from? how to solve it?
10 Replies 10
Could be a capacity issue. Cancel the reservation and start a new one.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
i already disabled the lab and enabled it again. but still not working.
@Mohamed Atallah as this is always on, there is no set up. I have the same screen you do, but if you click on the instruction icon and not the quick access, you will see the detail how to access this, via the ports open, including ssh (you can see my Mac iTerm here). Appears to be working fine.
Hope this helps.
could you please help me to know how to do this?
i don`t know how this work. i know how the older version works but i don`t know how this works.
could you please make a video or try to make with you online video screen meeting in order to explain to me how to this works and how to access this?
thanks
this is my facebook account
https://www.facebook.com/mohamed.atallah.712/
and this is my email on cisco webex
eng_m_atallah@aol.com
Hope this helps.
sir please continue. please show me how to put   routers and switchs? where are these devices?
@Mohamed Atallah that is not possible with the IOS XE on Cat8kv AlwaysOn sandbox, this is a single devices hosted on a VM within the devnet sandbox, there is no option to add other devices. If you are looking for a sandbox that has devices you can add and build your own design/topology look at the Cisco Modelling Labs sandbox here https://devnetsandbox.cisco.com/DevNet/catalog/cml-sandbox which is a reservation based sandbox
Hope this helps.
but sir i thought this icon which is IOS XE on Cat8kv Always on has some routers and switches PLUS IOS XE routers and that is why i reserved it.
anyway, i want to build a lab which has routers and switches and IOS XE routers. how could i do that? like what i did with GNS lab
Hope this helps.
