sandbox lab and TSP
Hi  .. need to understand which sandbox lab shall we use for testing. We have to do the CTI integration with CUCM 9.1.
Also what should we used for development tapi32.dll / CISCO TSP? do we need TSP if we are using sandbox lab for testing?
77 Replies 77
Can you please extend it till 17th March as it seems it will expire on Sunday.
Reservation has been extended to Friday 18th March 2016.
Joe
Can you please extend my lab reservation till 24th March
This is my lab address -
devnetsandboxlabs.cisco.com/rave03
Hello Bhushan-
I have extended your reservation for one week. Let me know if you have any questions.
Thanks!
Jacob
Hi.. my lab reservation has ended. Can you please activate my lab reservation and extend it till 1st April.
Hello Bhushan-
You lab is already extended past April 1st.
Please let me know if you have any questions.
Thanks!
Jacob
     I have configured CTI ports and IP communicator extensions in CUCM.
    In TAPI tester i can only see the CTI port line but not the IP communicator extensions. Need to understand how can i see the IP extensions in TAPI tester as i have to monitor the IP extension from my application.
The IPC should show up on the device list when it is associated to the TSP user.  As dialer.exe may not include code to handle dynamic addition of the device, you  may need to restart it.
Can you please extend my lab reservation till 15th April.
devnetsandboxlabs.cisco.com/rave10
devnetsandboxlabs.cisco.com/rave18
Unfortunately, your reservation cannot be extended at this time as the VLAN will be used by a different user. You can book another environment when the current one is completed.
Joe Kearns
We are working on important UCSF integration. And I have a lot of setup in Collaboration 11 sandbox.
Can you please extend our lab reservation:
  devnetsandboxlabs.cisco.com/rave18 till May 15.
Olga Khylkouskaya.
Can we access the CISCO switch (CTI manager/CUCM) without installing/using the CISCO TSP?
Can we install the CISCO TSP on server and application on another computer.
I have application running on computer A and want to access the TAPI services of computer B. Will it work?
Not directly.  The service on computer B could expose its own simple custom API to multiple additional clients (computer A), but any app directly interacting with TAPI will need to have TAPI installed.
(Note, JTAPI has equivalent capabilities and is cross-platform, though more suited to server-to-server scenarios.)
