sandbox lab and TSP
Hi  .. need to understand which sandbox lab shall we use for testing. We have to do the CTI integration with CUCM 9.1.
Also what should we used for development tapi32.dll / CISCO TSP? do we need TSP if we are using sandbox lab for testing?
77 Replies 77
It looks like the device you are attempting Make Call for is a 'CSF' (Client Services Framework) device, i.e. a virtual device that is used as the device type for Jabber PC clients.  Is this CSF device being instantiated at the time by a running Jabber softphone?  Note, you will not be able to make a call from a CSF device that does not have a running Jabber instantiating it...
Which devices should i create in CUCM so that i can test make and answer call using dialer/tapi dialer application.
Do i need to configure softphone or any other client to test this? I have to test this using sandbox lab.
Also can we test voice using sandbox lab?
If you don't have a Cisco hardware IP phone available, then you can definitely use softphones.  The Windows/Mac Jabber softphones work for this, as well as the older IP Communicator softphone.  You may need two PCs on which to install caller and callee softphones, or you can try using the TAPI Browser 2.0 app to instantiate a CTI Port virtual device.  Make sure these softphones are associated to your TAPI CUCM user.
Hi .. its working now.
Added the CTI permissions but still can not see the CISCO lines in dialer application.
Detailed TSP log -
16:49:44.164 HDR|03/01/2016 CiscoTSP001.tsp,Detailed
16:49:44.164 |   CTspTrace::Init() Tracing initialized. CiscoTSP_HKEY: [0x80000003]. CiscoTSP instance subkey: S-1-5-20\Software\Cisco Systems, Inc.\Cisco TSP\Cisco TSP001
16:49:44.164 |<--CTspTrace::Init()
16:49:44.164 |-->TSPI_lineNegotiateTSPIVersion()
16:49:44.164 |   TSPI_lineNegotiateTSPIVersion() dwDeviceID =0xFFFFFFFF dwLowVersion =0x00010003 dwHighVersion =0x00030001 lpdwTSPIVersion =0x0692506C
16:49:44.164 |-->InitGlobalTSP()
16:49:44.164 |-->CQBEHelperBase::CQBEHelperBase()
16:49:44.164 |   CQBEHelperBase::CQBEHelperBase() trace mask=0x007F0601
16:49:44.164 |<--CQBEHelperBase::CQBEHelperBase()
16:49:44.164 |-->CCiscoTSP_CodecList::CCiscoTSP_CodecList()
16:49:44.164 |<--CCiscoTSP_CodecList::CCiscoTSP_CodecList()
16:49:44.164 |-->CCiscoTSP_MediaMgr::CCiscoTSP_MediaMgr()
16:49:44.164 |<--CCiscoTSP_MediaMgr::CCiscoTSP_MediaMgr()
16:49:44.164 |-->CSelsiusTSPDeviceList::CSelsiusTSPDeviceList()
16:49:44.164 |<--CSelsiusTSPDeviceList::CSelsiusTSPDeviceList()
16:49:44.164 |-->CCiscoTSP_InactiveLineList::CCiscoTSP_InactiveLineList()
16:49:44.164 |<--CCiscoTSP_InactiveLineList::CCiscoTSP_InactiveLineList()
16:49:44.164 |-->CSelsiusTSPLineList::CSelsiusTSPLineList()
16:49:44.164 |<--CSelsiusTSPLineList::CSelsiusTSPLineList()
16:49:44.164 |-->CTspRequestMap::CTspRequestMap()
16:49:44.164 |<--CTspRequestMap::CTspRequestMap()
16:49:44.164 |-->CSelsiusTSP::CSelsiusTSP()
16:49:44.164 |   CSelsiusTSP::CSelsiusTSP() this=00000000075A7F00
16:49:44.164 |-->CSelsiusTSP::Initialize()
16:49:44.164 |   CSelsiusTSP::Initialize() SRTP IsKeyPassingAllowed = 1
16:49:44.164 |   CSelsiusTSP::Initialize() TSP Product Version 10.5(2.5)
16:49:44.164 |   CSelsiusTSP::Initialize() trace mask=0x007F0601
16:49:44.164 |   CSelsiusTSP::Initialize() m_EnumAutomatedVoiceOnly=0
16:49:44.164 |   CSelsiusTSP::Initialize() InstanceID not present in registry
16:49:44.164 |-->CSelsiusTSP::ReadUserNamePassword_TSP()
16:49:44.164 |   CSelsiusTSP::ReadUserNamePassword_TSP() user name=r pPswdLen_=32, foundPassword=0
16:49:44.164 |<--CSelsiusTSP::ReadUserNamePassword_TSP()
16:49:44.164 |   CSelsiusTSP::Initialize() m_CtiDscpValue=0x00000018
16:49:44.164 |   CSelsiusTSP::Initialize() m_WaveDscpValue=0x0000002E
16:49:44.164 |   CSelsiusTSP::Initialize() m_CMAssignedApplicationID=0
16:49:44.164 |   CSelsiusTSP::Initialize() EM Memory Optimization: Off
16:49:44.164 |   CSelsiusTSP::Initialize() Failed to read BlockDynamicData
16:49:44.164 |   CSelsiusTSP::Initialize() m_BlockDynamicDataFlag=0
16:49:44.164 |   CSelsiusTSP::Initialize() Failed to read BlockDynamicDevCapsData
16:49:44.164 |   CSelsiusTSP::Initialize() m_BlockDynamicDevCapsFlag=0
16:49:44.164 |   CSelsiusTSP::Initialize() Failed to read BlockDynamicPhoneCapsData
16:49:44.164 |   CSelsiusTSP::Initialize() m_BlockDynamicPhoneCapsData=0
16:49:44.164 |   CSelsiusTSP::Initialize() Failed to read CallDevSpecificEvtToFire
16:49:44.164 |   CSelsiusTSP::Initialize() m_CallDevSpecificEvtToFire=-1
16:49:44.164 |   CSelsiusTSP::Initialize() Failed to read UseModifiedDNForExternalParty
16:49:44.164 |   CSelsiusTSP::Initialize() m_UsingModifiedDNForExternalParty=0x00000000
16:49:44.164 |-->CSelsiusTSPSecureMemMgr::CSelsiusTSPSecureMemMgr()
16:49:44.164 |<--CSelsiusTSPSecureMemMgr::CSelsiusTSPSecureMemMgr()
16:49:44.164 |   CSelsiusTSP::Initialize() TAPI ProcessID = 1320
16:49:44.164 |   CSelsiusTSP::Initialize() Configured Media Driver type: 1, G729PassThrough: 0
16:49:44.164 |-->CCiscoTSP_MediaMgr::Init()
16:49:44.164 |-->rtpLibTrace:
16:49:44.164 |   rtpLibTrace:  [debug]   TSP API init: ok, lines=300
16:49:44.164 |<--rtpLibTrace:
16:49:44.164 |   rtpLibTrace:  [warning] RegQueryValueEx for HKEY_USERS/S-1-5-20\Software\Cisco Systems, Inc.\RTPLib/RTPDefaultAddrFamily: error=0x2(2) The system cannot find the file specified.
16:49:44.164 |   rtpLibTrace:  [warning] RegQueryValueEx for HKEY_USERS/S-1-5-20\Software\Cisco Systems, Inc.\RTPLib/RTPDefaultAddr: error=0x2(2) The system cannot find the file specified.
16:49:44.180 |-->rtpLibTrace:
16:49:44.180 |   rtpLibTrace:  [always]  RTP Library init (OK):
ports: 300
port[00000]=21100
port[00299]=21698
addresses:
192.168.203.19
192.168.4.129
192.168.44.1
192.168.111.1
16:49:44.180 |<--rtpLibTrace:
16:49:44.180 |   rtpLibTrace:  [always]  _RtpQosOpen handle: 696(0x2b8)
16:49:44.211 |-->rtpLibTrace:
16:49:44.211 |   rtpLibTrace:  [info]    SRTP_INIT PASSED
16:49:44.211 |<--rtpLibTrace:
16:49:44.211 |   rtpLibTrace:  [debug]   MM Timer started, resolution: 4 ms.
16:49:44.211 |   rtpLibTrace:  [always]  RTP Library started with 4 active timers.
16:49:44.211 |   CCiscoTSP_MediaMgr::Init() _TspApiInit() SUCCESS
16:49:44.211 |-->CCiscoTSP_MediaMgr::MediaResourceStats()
16:49:44.211 |<--CCiscoTSP_MediaMgr::MediaResourceStats()
16:49:44.211 |-->CCiscoTSP_CodecList::GetRtpLibCodecs()
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() nCodecs 4 nBufSize 72
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() pCodecList = 0x0807D140  pCodec+i = 0x0807D140
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() codecInfo.m_wf.wFormatTag = 0x00000133
16:49:44.211 |-->CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x133]
16:49:44.211 |   CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x133] CODEC Info: FormaTag [0x00000133] AvgBytesPerSec [0x000003E8] BitsPerSample [0x00000000]
16:49:44.211 |<--CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x133]
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() pCodecList = 0x0807D140  pCodec+i = 0x0807D152
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() codecInfo.m_wf.wFormatTag = 0x00000007
16:49:44.211 |-->CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x7]
16:49:44.211 |   CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x7] CODEC Info: FormaTag [0x00000007] AvgBytesPerSec [0x00001F40] BitsPerSample [0x00000008]
16:49:44.211 |<--CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x7]
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() pCodecList = 0x0807D140  pCodec+i = 0x0807D164
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() codecInfo.m_wf.wFormatTag = 0x00000006
16:49:44.211 |-->CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x6]
16:49:44.211 |   CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x6] CODEC Info: FormaTag [0x00000006] AvgBytesPerSec [0x00001F40] BitsPerSample [0x00000008]
16:49:44.211 |<--CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x6]
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() pCodecList = 0x0807D140  pCodec+i = 0x0807D176
16:49:44.211 |   CCiscoTSP_CodecList::GetRtpLibCodecs() codecInfo.m_wf.wFormatTag = 0x00000001
16:49:44.211 |-->CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x1]
16:49:44.211 |   CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x1] CODEC Info: FormaTag [0x00000001] AvgBytesPerSec [0x00003E80] BitsPerSample [0x00000010]
16:49:44.211 |<--CCiscoTSP_CodecList::codecMapAdd(): formatTag_  [0x1]
16:49:44.211 |<--CCiscoTSP_CodecList::GetRtpLibCodecs()
16:49:44.211 |<--CCiscoTSP_MediaMgr::Init()
16:49:44.211 |-->CSelsiusTSP::StartEventThread()
16:49:44.211 |   CSelsiusTSP::StartEventThread() Created event thread.
16:49:44.211 |<--CSelsiusTSP::StartEventThread()
16:49:44.211 |-->CSelsiusTSP::StartWorkerThread()
16:49:44.211 |-->SelsiusTSP::EventThreadEntry()
16:49:44.211 |-->SelsiusTSP::InitializeComObjects()
16:49:44.211 |   SelsiusTSP::InitializeComObjects() trace mask=0x007F0601
16:49:44.211 |   SelsiusTSP::InitializeComObjects() CoInitializeEx(0, COINIT_MULTITHREADED) OK
16:49:44.211 |   CSelsiusTSP::StartWorkerThread() Created worker thread.
16:49:44.211 |<--CSelsiusTSP::StartWorkerThread()
16:49:44.211 |-->CSelsiusTSP::StartNotificationThread()
16:49:44.211 |   SelsiusTSP::InitializeComObjects() CoInitializeSecurity() OK
16:49:44.211 |-->SelsiusTSP::WorkerThreadEntry()
16:49:44.211 |   SelsiusTSP::InitializeComObjects() GITInitialize() OK
16:49:44.211 |-->CSelsiusTSPWaveList::CSelsiusTSPWaveList()
16:49:44.211 |-->SelsiusTSP::WorkerLoop()
16:49:44.211 |   SelsiusTSP::WorkerLoop() worker thread waiting for signal from main thread that there is a request
16:49:44.211 |   CSelsiusTSP::StartNotificationThread() Created Notification thread.
16:49:44.211 |<--CSelsiusTSP::StartNotificationThread()
16:49:44.211 |-->CSelsiusTSP::NotificationThreadEntry()
16:49:44.211 |-->CSelsiusTSP::NotificationLoop()
16:49:44.211 |-->CSelsiusTSP::SetApplicationID()
16:49:44.211 |   CSelsiusTSP::NotificationLoop() OpenSubkey for S-1-5-20\Software\Cisco Systems, Inc.\Cisco TSP\Cisco TSP001 returns [0x00000000]
16:49:44.211 |   CSelsiusTSP::SetApplicationID() cBuf = rav-dsk-353
16:49:44.211 |   CSelsiusTSPWaveList::CSelsiusTSPWaveList() hostName: rav-dsk-353, hostent ptr: 0x01057D40
16:49:44.211 |   CSelsiusTSPWaveList::CSelsiusTSPWaveList() m_LocalIP: 0x13CBA8C0, phe->h_addr_list[0]: 0x01057D90
16:49:44.211 |   CSelsiusTSPWaveList::CSelsiusTSPWaveList() phe->h_addrtype: 2, phe->h_length: 4, phe->h_name: rav-dsk-353.rave-tech.co.in
16:49:44.211 |   CSelsiusTSPWaveList::CSelsiusTSPWaveList() IPaddr for CTI wave device registration = 192.168.203.19
16:49:44.211 |<--CSelsiusTSPWaveList::CSelsiusTSPWaveList()
16:49:44.211 |   CSelsiusTSP::SetApplicationID() hostent ptr = 0x01057CB0
16:49:44.211 |   CSelsiusTSP::SetApplicationID() phe->h_addr_list[0] = 0x01057D00
16:49:44.211 |   CSelsiusTSP::SetApplicationID() phe->h_addrtype = 2
                                                   phe->h_length = 4
                                                   phe->h_name = rav-dsk-353.rave-tech.co.in
16:49:44.211 |   CSelsiusTSP::SetApplicationID() ApplicationID=CiscoTSP001-192.168.203.19
16:49:44.211 |   CSelsiusTSP::SetApplicationID() Final ApplicationID=CiscoTSP001-192.168.203.19
16:49:44.211 |<--CSelsiusTSP::SetApplicationID()
16:49:44.211 |-->CSelsiusTSPWaveList::Init()
16:49:44.211 |   CSelsiusTSP::Initialize() Read m_TspUUID = 85f8804b-b87f-44b9-a399-87b938e25374
16:49:44.211 |-->CSelsiusTSP::createCtiInterface()
16:49:44.211 |-->CQBEHelperBase::CreateCtiInterface()
16:49:44.211 |   CQBEHelperBase::CreateCtiInterface() SyncMsg Timeout=15000 ,ProviderOpen Timeout=50000, Heartbeat Interval=30, ConnectRetry Interval=30000
16:49:44.211 |   CQBEHelperBase::CreateCtiInterface() QBE_DEBUG: Application=CiscoTSP001-192.168.203.19, ApplicationID length=26
16:49:44.211 |-->CCtiInterface::CCtiInterface()
16:49:44.211 |-->CCtiRequestMap::CCtiRequestMap()
16:49:44.211 |<--CCtiRequestMap::CCtiRequestMap()
16:49:44.211 |-->CCtiConnector::CCtiConnector()
16:49:44.211 |-->CCtiConnector::startConnectThread()
16:49:44.211 |   CSelsiusTSPWaveList::Init() *ERROR* Failed to get ISelsiusNTWaveCtl interface.
16:49:44.211 |<--CSelsiusTSPWaveList::Init()
16:49:44.211 |   SelsiusTSP::InitializeComObjects() *ERROR* Failed m_WaveList->Init(). hr=0x80040154
16:49:44.211 |<--SelsiusTSP::InitializeComObjects()
16:49:44.211 |   SelsiusTSP::EventThreadEntry() Signal that Event thread initialization is completed
16:49:44.211 |-->SelsiusTSP::SignalingLoop()
16:49:44.211 |   SelsiusTSP::SignalingLoop() Event thread waiting for signal
16:49:44.211 |   CCtiConnector::startConnectThread() Connect thread created: threadHandle=2720 threadId=3476
16:49:44.211 |<--CCtiConnector::startConnectThread()
16:49:44.211 |<--CCtiConnector::CCtiConnector()
16:49:44.211 |-->CCtiHeartbeat::CCtiHeartbeat()
16:49:44.211 |-->CCtiConnector::connectThreadEntry()
16:49:44.211 |-->CCtiInterface::ThreadEntryHook()
16:49:44.211 |-->CSelsiusTSP::ThreadEntryHook()
16:49:44.211 |<--CSelsiusTSP::ThreadEntryHook()
16:49:44.211 |<--CCtiInterface::ThreadEntryHook()
16:49:44.211 |-->CCtiConnector::connectLoop()
16:49:44.211 |-->CCtiHeartbeat::heartbeatThreadStart()
16:49:44.211 |   CCtiHeartbeat::heartbeatThreadStart() Heartbeat thread created: threadHandle=340 threadId=3004
16:49:44.211 |<--CCtiHeartbeat::heartbeatThreadStart()
16:49:44.211 |<--CCtiHeartbeat::CCtiHeartbeat()
16:49:44.211 |-->CCtiReceiver::CCtiReceiver()
16:49:44.211 |<--CCtiReceiver::CCtiReceiver()
16:49:44.211 |<--CCtiInterface::CCtiInterface()
16:49:44.211 |-->CCtiInterface::Init()
16:49:44.211 |-->CCtiHeartbeat::heartbeatThreadEntry()
16:49:44.211 |-->CCtiHeartbeat::heartbeatLoop()
16:49:44.211 |   CCtiHeartbeat::heartbeatLoop() Waiting for 30000 mseconds
16:49:44.211 |-->CSelsiusTSPLink::CSelsiusTCPLink()
16:49:44.211 |<--CSelsiusTSPLink::CSelsiusTCPLink()
16:49:44.211 |<--CCtiInterface::Init()
16:49:44.211 |   CQBEHelperBase::CreateCtiInterface() Created CCtiInterface object: 00000000075C5A00
16:49:44.211 |<--CQBEHelperBase::CreateCtiInterface()
16:49:44.211 |   CSelsiusTSP::createCtiInterface() Created CtiInterface object [0x075C5A00].
16:49:44.211 |<--CSelsiusTSP::createCtiInterface()
16:49:44.211 |   CSelsiusTSP::Initialize() CtiInterface created - [0x075C5A00].
16:49:44.211 |-->CCtiInterface::ctiConnect()
16:49:44.211 |-->CQBEHelperBase::CreateCtiLink()
16:49:44.211 |-->CQBEHelperBase::SetTspState()
16:49:44.211 |   CQBEHelperBase::SetTspState() TSPState = 1
16:49:44.211 |<--CQBEHelperBase::SetTspState()
16:49:44.211 |-->CQBEHelperBase::ConnectToCtiManager()
16:49:44.211 |   CQBEHelperBase::ConnectToCtiManager() m_TspConnectState = TspConnectState_StartConnect, m_LastCtiManagerIndexAttemptedForConnection = -1
16:49:44.211 |-->CSelsiusTSP::ReadCtiMgrLocation()
16:49:44.211 |-->CSelsiusTSP::ReadPreferredAddressingMode()
16:49:44.211 |<--CSelsiusTSP::ReadPreferredAddressingMode()
16:49:44.211 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager is IP address [64.103.37.21]
16:49:44.211 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager address: 0x15256740
16:49:44.211 |   CSelsiusTSP::ReadCtiMgrLocation() Backup CTI Manager is not configured
16:49:44.211 |<--CSelsiusTSP::ReadCtiMgrLocation()
16:49:44.211 |   CQBEHelperBase::ConnectToCtiManager() ReadCtiMgrLocation() returned 0
16:49:44.211 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[0] : configured =1 preference =0 IPv4FailureType =0 IPv6FailureType = 3
16:49:44.211 |-->CCtiInterface::ConnectLink()
16:49:44.211 |-->CSelsiusTSPLink::createSocket()
16:49:44.211 |<--CSelsiusTSPLink::createSocket()
16:49:44.211 |-->CSelsiusTSPLink::Connect()
16:50:05.227 |   CSelsiusTSPLink::Connect() *ERROR* Failed to connect to CTI Manager: error=10060
16:50:05.227 |   CSelsiusTSPLink::Connect() hSocket=648. Link status - 0
16:50:05.227 |<--CSelsiusTSPLink::Connect()
16:50:05.227 |-->CCtiInterface::CloseLink()
16:50:05.227 |   CCtiInterface::CloseLink() Closing connection to CTI Manager
16:50:05.227 |-->CSelsiusTSPLink::CloseLink(2)
16:50:05.227 |-->CSelsiusTSPLink::RemoveQwaveFunctionality()
16:50:05.227 |<--CSelsiusTSPLink::RemoveQwaveFunctionality()
16:50:05.227 |   CSelsiusTSPLink::CloseLink(2) hSocket=-1. Link status - 2
16:50:05.227 |<--CSelsiusTSPLink::CloseLink(2)
16:50:05.227 |-->CCtiReceiver::stopReceiveThread()
16:50:05.227 |<--CCtiReceiver::stopReceiveThread()
16:50:05.227 |-->CCtiHeartbeat::stopHeartbeat()
16:50:05.227 |<--CCtiHeartbeat::stopHeartbeat()
16:50:05.227 |<--CCtiInterface::CloseLink()
16:50:05.227 |<--CCtiInterface::ConnectLink()
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected using IPv4, trying IPv6.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[1] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected using IPv4, trying IPv6.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[2] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected using IPv4, trying IPv6.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[3] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected using IPv4, trying IPv6.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[4] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected using IPv4, trying IPv6.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[5] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected using IPv4, trying IPv6.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected.
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[6] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.227 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[7] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[8] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[9] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[10] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[11] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[12] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[13] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[14] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[15] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[16] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[17] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[18] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[19] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[20] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[21] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[22] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected using IPv4, trying IPv6.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected.
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[23] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.228 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[24] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[25] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[26] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[27] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[28] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[29] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[30] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[31] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[32] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[33] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[34] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[35] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[36] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[37] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[38] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[39] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected using IPv4, trying IPv6.
16:50:05.229 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected.
16:50:05.229 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:50:05.229 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:50:05.230 |   CSelsiusTSP::SetTSPInitErrorCode() SendInfotoNotifier returned= 0
16:50:05.230 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:50:05.230 |<--CQBEHelperBase::ConnectToCtiManager()
16:50:05.230 |   CQBEHelperBase::CreateCtiLink() Unable to connect to CTI Manager
16:50:05.230 |<--CQBEHelperBase::CreateCtiLink()
16:50:05.230 |   CCtiInterface::ctiConnect() Unable to connect to CTI Manager. Signal Connector to retry.
16:50:05.230 |-->CCtiInterface::StartReconnectProcess()
16:50:05.230 |   CCtiInterface::StartReconnectProcess() Setting the reconnect signal
16:50:05.230 |-->CCtiConnector::startConnecting()
16:50:05.230 |-->CCtiConnector::resumeConnectThread()
16:50:05.230 |<--CCtiConnector::resumeConnectThread()
16:50:05.230 |<--CCtiConnector::startConnecting()
16:50:05.230 |<--CCtiInterface::StartReconnectProcess()
16:50:05.230 |<--CCtiInterface::ctiConnect()
16:50:05.230 |<--CSelsiusTSP::Initialize()
16:50:05.230 |<--CSelsiusTSP::CSelsiusTSP()
16:50:05.230 |<--InitGlobalTSP()
16:50:05.230 |   CCtiConnector::connectLoop() Received signal to connect
16:50:05.231 |   CCtiConnector::connectLoop() Waiting for 100 msec to do reconnection
16:50:05.231 |-->SelsiusTSP::TSPI_lineNegotiateTSPIVersion(-1)
16:50:05.231 |   SelsiusTSP::TSPI_lineNegotiateTSPIVersion(-1) TSPI Version is 0x00020001
16:50:05.231 |<--SelsiusTSP::TSPI_lineNegotiateTSPIVersion(-1)
16:50:05.231 |   TSPI_lineNegotiateTSPIVersion()
        TSPI_lineNegotiateTSPIVersion returns = 0x00000000
        TSPI return version = 0x00020001
16:50:05.231 |<--TSPI_lineNegotiateTSPIVersion()
16:50:05.231 |-->TSPI_providerEnumDevices()
16:50:05.231 |   TSPI_providerEnumDevices()
        dwPermanentProviderID = 0x00000006
        hProvider = 0x06925050
        lpfnLineCreateProc = 0xEDE8C930
        lpfnPhoneCreateProc = 0xEDEA2D6C
16:50:05.231 |-->SelsiusTSP::TSPI_providerEnumDevices()
16:50:05.231 |   SelsiusTSP::TSPI_providerEnumDevices() CiscoTSP is OUT_OF_SERVICE, 0 lines and 0 devices returned
16:50:05.231 |   SelsiusTSP::TSPI_providerEnumDevices() Returning 0 lines 0 phones.
16:50:05.231 |<--SelsiusTSP::TSPI_providerEnumDevices()
        TSPI_providerEnumDevices returns = 0x00000000
        dwNumLines = 0
        dwNumPhones = 0
16:50:05.231 |<--TSPI_providerEnumDevices()
16:50:05.231 |-->TSPI_providerInit()
16:50:05.231 |   TSPI_providerInit()
        dwTSPIVersion = 0x00020001
        lpfnCompletionProc = 0xEDEABDB8
16:50:05.231 |-->SelsiusTSP::TSPI_providerInit()
16:50:05.231 |   SelsiusTSP::TSPI_providerInit() m_pfnCompletionProc=0xEDEABDB8
16:50:05.231 |   SelsiusTSP::TSPI_providerInit() dwLineDeviceIDBase=5,dwPhoneDeviceIDBase=0,dwPermanentProviderID=6
16:50:05.231 |<--SelsiusTSP::TSPI_providerInit()
        TSPI_providerInit returns = 0x00000000
        dwLineDeviceIDBase = 0x00000005
        dwPhoneDeviceIDBase = 0x00000000
        dwNumLines = 0
        dwNumPhones = 0
        lpdwTSPIOptions = 0x06925068
16:50:05.231 |<--TSPI_providerInit()
16:50:05.331 |   CCtiConnector::connectLoop() Time-out
16:50:05.331 |-->CCtiInterface::connectToCtiManager()
16:50:05.331 |-->CQBEHelperBase::ConnectToCtiManager()
16:50:05.331 |   CQBEHelperBase::ConnectToCtiManager() m_TspConnectState = TspConnectState_ConnectInProgress, m_LastCtiManagerIndexAttemptedForConnection = -1
16:50:05.331 |-->CSelsiusTSP::ReadCtiMgrLocation()
16:50:05.331 |-->CSelsiusTSP::ReadPreferredAddressingMode()
16:50:05.331 |<--CSelsiusTSP::ReadPreferredAddressingMode()
16:50:05.331 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager is IP address [64.103.37.21]
16:50:05.331 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager address: 0x15256740
16:50:05.331 |   CSelsiusTSP::ReadCtiMgrLocation() Backup CTI Manager is not configured
16:50:05.331 |<--CSelsiusTSP::ReadCtiMgrLocation()
16:50:05.331 |   CQBEHelperBase::ConnectToCtiManager() ReadCtiMgrLocation() returned 0
16:50:05.331 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[0] : configured =1 preference =0 IPv4FailureType =0 IPv6FailureType = 3
16:50:05.331 |-->CCtiInterface::ConnectLink()
16:50:05.331 |-->CSelsiusTSPLink::createSocket()
16:50:05.331 |<--CSelsiusTSPLink::createSocket()
16:50:05.331 |-->CSelsiusTSPLink::Connect()
16:50:14.212 |   CCtiHeartbeat::heartbeatLoop() Time-out. wait() return=-1 waitTimeout=30000
16:50:14.212 |   CCtiHeartbeat::heartbeatLoop() Heartbeat suspended
16:50:14.212 |   CCtiHeartbeat::heartbeatLoop() Waiting for -1 mseconds
16:50:26.335 |   CSelsiusTSPLink::Connect() *ERROR* Failed to connect to CTI Manager: error=10060
16:50:26.335 |   CSelsiusTSPLink::Connect() hSocket=3264. Link status - 2
16:50:26.335 |<--CSelsiusTSPLink::Connect()
16:50:26.335 |-->CCtiInterface::CloseLink()
16:50:26.335 |   CCtiInterface::CloseLink() Closing connection to CTI Manager
16:50:26.335 |-->CSelsiusTSPLink::CloseLink(2)
16:50:26.335 |-->CSelsiusTSPLink::RemoveQwaveFunctionality()
16:50:26.335 |<--CSelsiusTSPLink::RemoveQwaveFunctionality()
16:50:26.335 |   CSelsiusTSPLink::CloseLink(2) hSocket=-1. Link status - 2
16:50:26.335 |<--CSelsiusTSPLink::CloseLink(2)
16:50:26.335 |-->CCtiReceiver::stopReceiveThread()
16:50:26.335 |<--CCtiReceiver::stopReceiveThread()
16:50:26.335 |-->CCtiHeartbeat::stopHeartbeat()
16:50:26.335 |<--CCtiHeartbeat::stopHeartbeat()
16:50:26.335 |<--CCtiInterface::CloseLink()
16:50:26.335 |<--CCtiInterface::ConnectLink()
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[1] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[2] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[3] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[4] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[5] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[6] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[7] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected using IPv4, trying IPv6.
16:50:26.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[8] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[9] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[10] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[11] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[12] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[13] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[14] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[15] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[16] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[17] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[18] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[19] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[20] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[21] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[22] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[23] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[24] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected using IPv4, trying IPv6.
16:50:26.336 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[25] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[26] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[27] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[28] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[29] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[30] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[31] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[32] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[33] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[34] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[35] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[36] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[37] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[38] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[39] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected using IPv4, trying IPv6.
16:50:26.337 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected.
16:50:26.337 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:50:26.337 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:50:26.338 |   CSelsiusTSP::SetTSPInitErrorCode() SendInfotoNotifier returned= 0
16:50:26.338 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:50:26.338 |<--CQBEHelperBase::ConnectToCtiManager()
16:50:26.338 |<--CCtiInterface::connectToCtiManager()
16:50:26.338 |   CCtiConnector::connectLoop() Unable to connect to any of the configured CTI Managers.
16:50:26.338 |-->CCtiInterface::setInitErrorCode()
16:50:26.338 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:50:26.338 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:50:26.338 |<--CCtiInterface::setInitErrorCode()
16:50:26.338 |-->CCtiInterface::StartReconnectProcess()
16:50:26.338 |   CCtiInterface::StartReconnectProcess() Setting the reconnect signal
16:50:26.338 |-->CCtiConnector::startConnecting()
16:50:26.338 |-->CCtiConnector::resumeConnectThread()
16:50:26.338 |<--CCtiConnector::resumeConnectThread()
16:50:26.338 |<--CCtiConnector::startConnecting()
16:50:26.338 |<--CCtiInterface::StartReconnectProcess()
16:50:26.339 |   CCtiConnector::connectLoop() Received signal to connect
16:50:26.339 |   CCtiConnector::connectLoop() Waiting for 59000 msec to do reconnection
16:51:25.339 |   CCtiConnector::connectLoop() Time-out
16:51:25.339 |-->CCtiInterface::connectToCtiManager()
16:51:25.339 |-->CQBEHelperBase::ConnectToCtiManager()
16:51:25.339 |   CQBEHelperBase::ConnectToCtiManager() m_TspConnectState = TspConnectState_ConnectInProgress, m_LastCtiManagerIndexAttemptedForConnection = -1
16:51:25.339 |-->CSelsiusTSP::ReadCtiMgrLocation()
16:51:25.339 |-->CSelsiusTSP::ReadPreferredAddressingMode()
16:51:25.339 |<--CSelsiusTSP::ReadPreferredAddressingMode()
16:51:25.339 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager is IP address [64.103.37.21]
16:51:25.339 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager address: 0x15256740
16:51:25.339 |   CSelsiusTSP::ReadCtiMgrLocation() Backup CTI Manager is not configured
16:51:25.339 |<--CSelsiusTSP::ReadCtiMgrLocation()
16:51:25.339 |   CQBEHelperBase::ConnectToCtiManager() ReadCtiMgrLocation() returned 0
16:51:25.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[0] : configured =1 preference =0 IPv4FailureType =0 IPv6FailureType = 3
16:51:25.339 |-->CCtiInterface::ConnectLink()
16:51:25.339 |-->CSelsiusTSPLink::createSocket()
16:51:25.339 |<--CSelsiusTSPLink::createSocket()
16:51:25.339 |-->CSelsiusTSPLink::Connect()
16:51:46.333 |   CSelsiusTSPLink::Connect() *ERROR* Failed to connect to CTI Manager: error=10060
16:51:46.333 |   CSelsiusTSPLink::Connect() hSocket=1656. Link status - 2
16:51:46.333 |<--CSelsiusTSPLink::Connect()
16:51:46.333 |-->CCtiInterface::CloseLink()
16:51:46.333 |   CCtiInterface::CloseLink() Closing connection to CTI Manager
16:51:46.333 |-->CSelsiusTSPLink::CloseLink(2)
16:51:46.333 |-->CSelsiusTSPLink::RemoveQwaveFunctionality()
16:51:46.333 |<--CSelsiusTSPLink::RemoveQwaveFunctionality()
16:51:46.333 |   CSelsiusTSPLink::CloseLink(2) hSocket=-1. Link status - 2
16:51:46.333 |<--CSelsiusTSPLink::CloseLink(2)
16:51:46.333 |-->CCtiReceiver::stopReceiveThread()
16:51:46.333 |<--CCtiReceiver::stopReceiveThread()
16:51:46.333 |-->CCtiHeartbeat::stopHeartbeat()
16:51:46.333 |<--CCtiHeartbeat::stopHeartbeat()
16:51:46.333 |<--CCtiInterface::CloseLink()
16:51:46.333 |<--CCtiInterface::ConnectLink()
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[1] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[2] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[3] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[4] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[5] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[6] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected using IPv4, trying IPv6.
16:51:46.333 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[7] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[8] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[9] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[10] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[11] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[12] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[13] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[14] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[15] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[16] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[17] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[18] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[19] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[20] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[21] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[22] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[23] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected using IPv4, trying IPv6.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected.
16:51:46.334 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[24] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[25] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[26] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[27] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[28] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[29] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[30] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[31] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[32] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[33] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[34] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[35] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[36] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[37] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[38] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[39] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected using IPv4, trying IPv6.
16:51:46.335 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected.
16:51:46.336 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:51:46.336 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:51:46.336 |   CSelsiusTSP::SetTSPInitErrorCode() SendInfotoNotifier returned= 0
16:51:46.336 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:51:46.336 |<--CQBEHelperBase::ConnectToCtiManager()
16:51:46.336 |<--CCtiInterface::connectToCtiManager()
16:51:46.336 |   CCtiConnector::connectLoop() Unable to connect to any of the configured CTI Managers.
16:51:46.336 |-->CCtiInterface::setInitErrorCode()
16:51:46.337 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:51:46.337 |<--CCtiInterface::setInitErrorCode()
16:51:46.337 |-->CCtiInterface::StartReconnectProcess()
16:51:46.337 |   CCtiInterface::StartReconnectProcess() Setting the reconnect signal
16:51:46.337 |-->CCtiConnector::startConnecting()
16:51:46.337 |-->CCtiConnector::resumeConnectThread()
16:51:46.337 |<--CCtiConnector::resumeConnectThread()
16:51:46.337 |<--CCtiConnector::startConnecting()
16:51:46.337 |<--CCtiInterface::StartReconnectProcess()
16:51:46.337 |   CCtiConnector::connectLoop() Received signal to connect
16:51:46.337 |   CCtiConnector::connectLoop() Waiting for 51000 msec to do reconnection
16:52:37.338 |   CCtiConnector::connectLoop() Time-out
16:52:37.338 |-->CCtiInterface::connectToCtiManager()
16:52:37.338 |-->CQBEHelperBase::ConnectToCtiManager()
16:52:37.338 |   CQBEHelperBase::ConnectToCtiManager() m_TspConnectState = TspConnectState_ConnectInProgress, m_LastCtiManagerIndexAttemptedForConnection = -1
16:52:37.338 |-->CSelsiusTSP::ReadCtiMgrLocation()
16:52:37.338 |-->CSelsiusTSP::ReadPreferredAddressingMode()
16:52:37.338 |<--CSelsiusTSP::ReadPreferredAddressingMode()
16:52:37.338 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager is IP address [64.103.37.21]
16:52:37.338 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager address: 0x15256740
16:52:37.338 |   CSelsiusTSP::ReadCtiMgrLocation() Backup CTI Manager is not configured
16:52:37.338 |<--CSelsiusTSP::ReadCtiMgrLocation()
16:52:37.338 |   CQBEHelperBase::ConnectToCtiManager() ReadCtiMgrLocation() returned 0
16:52:37.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[0] : configured =1 preference =0 IPv4FailureType =0 IPv6FailureType = 3
16:52:37.338 |-->CCtiInterface::ConnectLink()
16:52:37.338 |-->CSelsiusTSPLink::createSocket()
16:52:37.338 |<--CSelsiusTSPLink::createSocket()
16:52:37.338 |-->CSelsiusTSPLink::Connect()
16:52:58.338 |   CSelsiusTSPLink::Connect() *ERROR* Failed to connect to CTI Manager: error=10060
16:52:58.338 |   CSelsiusTSPLink::Connect() hSocket=2516. Link status - 2
16:52:58.338 |<--CSelsiusTSPLink::Connect()
16:52:58.338 |-->CCtiInterface::CloseLink()
16:52:58.338 |   CCtiInterface::CloseLink() Closing connection to CTI Manager
16:52:58.338 |-->CSelsiusTSPLink::CloseLink(2)
16:52:58.338 |-->CSelsiusTSPLink::RemoveQwaveFunctionality()
16:52:58.338 |<--CSelsiusTSPLink::RemoveQwaveFunctionality()
16:52:58.338 |   CSelsiusTSPLink::CloseLink(2) hSocket=-1. Link status - 2
16:52:58.338 |<--CSelsiusTSPLink::CloseLink(2)
16:52:58.338 |-->CCtiReceiver::stopReceiveThread()
16:52:58.338 |<--CCtiReceiver::stopReceiveThread()
16:52:58.338 |-->CCtiHeartbeat::stopHeartbeat()
16:52:58.338 |<--CCtiHeartbeat::stopHeartbeat()
16:52:58.338 |<--CCtiInterface::CloseLink()
16:52:58.338 |<--CCtiInterface::ConnectLink()
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[1] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[2] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[3] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[4] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[5] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[6] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected using IPv4, trying IPv6.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected.
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[7] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.338 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[8] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[9] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[10] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[11] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[12] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[13] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[14] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[15] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[16] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[17] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[18] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[19] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[20] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[21] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[22] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[23] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected using IPv4, trying IPv6.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected.
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[24] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.339 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[25] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[26] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[27] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[28] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[29] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[30] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[31] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[32] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[33] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[34] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[35] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[36] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[37] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[38] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[39] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected using IPv4, trying IPv6.
16:52:58.340 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected.
16:52:58.340 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:52:58.340 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:52:58.341 |   CSelsiusTSP::SetTSPInitErrorCode() SendInfotoNotifier returned= 0
16:52:58.341 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:52:58.341 |<--CQBEHelperBase::ConnectToCtiManager()
16:52:58.341 |<--CCtiInterface::connectToCtiManager()
16:52:58.341 |   CCtiConnector::connectLoop() Unable to connect to any of the configured CTI Managers.
16:52:58.341 |-->CCtiInterface::setInitErrorCode()
16:52:58.341 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:52:58.341 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:52:58.342 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:52:58.342 |<--CCtiInterface::setInitErrorCode()
16:52:58.342 |-->CCtiInterface::StartReconnectProcess()
16:52:58.342 |   CCtiInterface::StartReconnectProcess() Setting the reconnect signal
16:52:58.342 |-->CCtiConnector::startConnecting()
16:52:58.342 |-->CCtiConnector::resumeConnectThread()
16:52:58.342 |<--CCtiConnector::resumeConnectThread()
16:52:58.342 |<--CCtiConnector::startConnecting()
16:52:58.342 |<--CCtiInterface::StartReconnectProcess()
16:52:58.342 |   CCtiConnector::connectLoop() Received signal to connect
16:52:58.342 |   CCtiConnector::connectLoop() Waiting for 49000 msec to do reconnection
16:53:47.343 |   CCtiConnector::connectLoop() Time-out
16:53:47.343 |-->CCtiInterface::connectToCtiManager()
16:53:47.343 |-->CQBEHelperBase::ConnectToCtiManager()
16:53:47.343 |   CQBEHelperBase::ConnectToCtiManager() m_TspConnectState = TspConnectState_ConnectInProgress, m_LastCtiManagerIndexAttemptedForConnection = -1
16:53:47.343 |-->CSelsiusTSP::ReadCtiMgrLocation()
16:53:47.343 |-->CSelsiusTSP::ReadPreferredAddressingMode()
16:53:47.343 |<--CSelsiusTSP::ReadPreferredAddressingMode()
16:53:47.343 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager is IP address [64.103.37.21]
16:53:47.343 |   CSelsiusTSP::ReadCtiMgrLocation() Primary CTI Manager address: 0x15256740
16:53:47.343 |   CSelsiusTSP::ReadCtiMgrLocation() Backup CTI Manager is not configured
16:53:47.343 |<--CSelsiusTSP::ReadCtiMgrLocation()
16:53:47.343 |   CQBEHelperBase::ConnectToCtiManager() ReadCtiMgrLocation() returned 0
16:53:47.343 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[0] : configured =1 preference =0 IPv4FailureType =0 IPv6FailureType = 3
16:53:47.343 |-->CCtiInterface::ConnectLink()
16:53:47.343 |-->CSelsiusTSPLink::createSocket()
16:53:47.343 |<--CSelsiusTSPLink::createSocket()
16:53:47.343 |-->CSelsiusTSPLink::Connect()
16:54:08.350 |   CSelsiusTSPLink::Connect() *ERROR* Failed to connect to CTI Manager: error=10060
16:54:08.350 |   CSelsiusTSPLink::Connect() hSocket=2388. Link status - 2
16:54:08.350 |<--CSelsiusTSPLink::Connect()
16:54:08.350 |-->CCtiInterface::CloseLink()
16:54:08.350 |   CCtiInterface::CloseLink() Closing connection to CTI Manager
16:54:08.350 |-->CSelsiusTSPLink::CloseLink(2)
16:54:08.350 |-->CSelsiusTSPLink::RemoveQwaveFunctionality()
16:54:08.350 |<--CSelsiusTSPLink::RemoveQwaveFunctionality()
16:54:08.350 |   CSelsiusTSPLink::CloseLink(2) hSocket=-1. Link status - 2
16:54:08.350 |<--CSelsiusTSPLink::CloseLink(2)
16:54:08.350 |-->CCtiReceiver::stopReceiveThread()
16:54:08.350 |<--CCtiReceiver::stopReceiveThread()
16:54:08.350 |-->CCtiHeartbeat::stopHeartbeat()
16:54:08.350 |<--CCtiHeartbeat::stopHeartbeat()
16:54:08.350 |<--CCtiInterface::CloseLink()
16:54:08.350 |<--CCtiInterface::ConnectLink()
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[0]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[1] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[1]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[2] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[2]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[3] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[3]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[4] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[4]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[5] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[5]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[6] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected using IPv4, trying IPv6.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[6]: Unable to connected.
16:54:08.350 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[7] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[7]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[8] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[8]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[9] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[9]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[10] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[10]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[11] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[11]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[12] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[12]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[13] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[13]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[14] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[14]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[15] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[15]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[16] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[16]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[17] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[17]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[18] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[18]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[19] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[19]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[20] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[20]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[21] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[21]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[22] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[22]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[23] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected using IPv4, trying IPv6.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[23]: Unable to connected.
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[24] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.351 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[24]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[25] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[25]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[26] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[26]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[27] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[27]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[28] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[28]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[29] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[29]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[30] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[30]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[31] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[31]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[32] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[32]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[33] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[33]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[34] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[34]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[35] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[35]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[36] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[36]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[37] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[37]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[38] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[38]: Unable to connected.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CtiManager[39] : configured =0 preference =0 IPv4FailureType =3 IPv6FailureType = 3
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected using IPv4, trying IPv6.
16:54:08.352 |   CQBEHelperBase::ConnectToCtiManager() CTIManager[39]: Unable to connected.
16:54:08.352 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:54:08.352 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:54:08.353 |   CSelsiusTSP::SetTSPInitErrorCode() SendInfotoNotifier returned= 0
16:54:08.353 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:54:08.353 |<--CQBEHelperBase::ConnectToCtiManager()
16:54:08.353 |<--CCtiInterface::connectToCtiManager()
16:54:08.353 |   CCtiConnector::connectLoop() Unable to connect to any of the configured CTI Managers.
16:54:08.353 |-->CCtiInterface::setInitErrorCode()
16:54:08.353 |-->CSelsiusTSP::SetTSPInitErrorCode()
16:54:08.353 |   CSelsiusTSP::SetTSPInitErrorCode() GetTspConnectState = 16
16:54:08.354 |<--CSelsiusTSP::SetTSPInitErrorCode()
16:54:08.354 |<--CCtiInterface::setInitErrorCode()
16:54:08.354 |-->CCtiInterface::StartReconnectProcess()
16:54:08.354 |   CCtiInterface::StartReconnectProcess() Setting the reconnect signal
16:54:08.354 |-->CCtiConnector::startConnecting()
16:54:08.354 |-->CCtiConnector::resumeConnectThread()
16:54:08.354 |<--CCtiConnector::resumeConnectThread()
16:54:08.354 |<--CCtiConnector::startConnecting()
16:54:08.354 |<--CCtiInterface::StartReconnectProcess()
16:54:08.354 |   CCtiConnector::connectLoop() Received signal to connect
16:54:08.354 |   CCtiConnector::connectLoop() Waiting for 41000 msec to do reconnection
Can you please extend my current sandbox lab reservation? I am trying to do it but getting message -
"Could not save the reservation. The following issues were found. Reservation exceeds maximum duration"
This is my lab address -
devnetsandboxlabs.cisco.com/rave03
Hi Bhushan,
Your sandbox has been extended by four days.
Joe
Can we test voice using sandbox lab?
Scenario trying to test -
1. Configured CTI ports in sandbox
2. Open CTI port (5000) on first machine (using dialer/tapi dialer)
3. Open CTI port (5001) on another machine (using dialer/tapi dialer)
4. Making call from 5000 to 5001
5. Answer call on 5001
Can both the users talk? Can they listen voice of each other?  Is this possible using sandbox lab?
Yes. Voice and Video are available in the Sandbox.
What phone devices are you controlling?
Joe
I am using CTI ports.
I don't believe the TAPI dialer will be able to successfully instantiate and use a CTI Port device.  Most TAPI scenarios/apps (including dialer.exe) involved 3rd party call control - i.e. acting as a third party which monitors and controls an independent telephony device (such as a modem, or a Cisco VoIP phone.)  CTI Ports are virtual device (not standalone), and require a specially programmed application to instantiate and register them - i.e 1st party call control.
You can use dialer.exe to perform TAPI-based 'remote control' of standalone devices - including softphone devices like Jabber for Mac/Windows and IP Communicator (windows only).
I can monitor and open the CIT port devices. Can make call from one device to another device and can answer the call from another workstation.
but can not hear voice. Speaker and headset options seems disabled in tapi phone dialer.
Ref attached snapshot. I have made call from CTI port 5001 to 5000 (which is open on another machine and answer the call)
Can see call state connected on both the machines. I click on phone option where speakerphone and headset options are disabled.snap.jpg
I believe what you are seeing is expected.  A TSP controlled CTI Port must provide application handling of media based on the Cisco TSP media driver and related audio API, which dialer.exe is not set up to use.
As mentioned, if you want to test live audio calls, you will need to use Jabber or IP Communicator, which are full standalone softphones with media handling.
Can you please extend my lab reservation ?
I have extended your reservation by 2 days.
Joe
