Trouble with Identity Service Engine Sandboxes
Paul Hanton
Tried the reservable sandbox and received VPN address as None, Tried the Always-On Sandbox Lab and the password details are not working. Is there problems with the labs atm?
I just saw this for another sandbox https://community.cisco.com/t5/devnet-sandbox/vpn-lab-network-address-is-none/td-p/4991617/jump-to/first-unread-message which look to be the same issue. Suggest cancel the reservation and start a new one see if this was a build error. The AO, team will have to check as often people change the password which the admin have to reset.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
