Unable to Connect to SandBox using anyconnect
chgajjar
Hi There,
I was able to successfully connect to sandbox at 128.107.93.228:20137 until i had my PC gone to sleep mode.
after turning on my PC and trying again to connect to VPN using any-connect i get below error:
The secure gateway has rejected the connection attempt.  A new connection attempt to the same or another secure gateway is needed, which requires re-authentication. The following message was received from the secure gateway: No assigned address
any help is appreciated.
Chintan
jacoadam
Level 5
Level 5
Please let me know your devnet username and I will fix this issue for you.
Thanks!
Jacob
Hi Jacob,
My Username is chgajjar
Thanks Again.
