el 01-07-2013 04:53 AM
Quisiera saber si el siguiente equipamiento esta en garantia :
sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 16:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
MAT-5.1 uptime is 13 weeks, 10 hours, 52 minutes
System restarted at 02:50:36 MAD Mon Oct 8 2012
System image file is "flash:/c2960s-universalk9-mz.122-55.SE3/c2960s-universalk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C2960S-48TS-S (PowerPC) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1602Y0Q3
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
50 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : D4:A0:2A:7B:67:80
Motherboard assembly number : 73-12424-07
Power supply part number : 341-0327-04
Motherboard serial number : FOC16014CLU
Power supply serial number : DCA1547P1UM
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C2960S-48TS-S
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC16017GNV
System serial number : FOC1602Y0Q3
Top Assembly Part Number : 800-32452-04
Top Assembly Revision Number : C0
Version ID : V04
CLEI Code Number : COMGK00ARD
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960S-48TS-S 12.2(55)SE3 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Un saludo y gracias de antemano
el 01-29-2013 09:23 AM
Hola Nacho, mi nombre es Johnnatan y soy parte de la comunidad de soporte de Cisco, puedes revisar la garantía en cisco.com, solamente busca tu país y rellena los espacios que el asistente te pida. Te dejo el link del sitio.
http://www.cisco.com/en/US/products/prod_warranties_listing.html
Espero esta respuesta te sea de utilidad y por favor si esta respuesta te fue de utilidad por favor márcala como respondida o calificala con estrellas, de esta forma me ayudas a que califiquen mi trabajo.
Gracias!!!!
Saludos
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
