cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
ASR1004 - 6506 TGiga Conexion Problem
csco11665954
I have at 6506 and ASR1004, they are conection for TenGiGA Fibra.
The EIGRP is flapping and el ASR send  next log:
*Jul  2 16:48:47.004: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
*Jul  2 16:49:16.383: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
*Jul  2 16:49:19.290: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
*Jul  2 16:49:29.764: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
*Jul  2 16:50:19.201: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
*Jul  2 16:50:31.647: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
*Jul  2 16:50:35.543: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
2 RESPUESTAS 2
bzendeja
Hi Gabriel,
ASR1k is detecting an issue with the remote end. Can you send the following information?
- Which transceiver are you using in both sides? Attach a show inventory from both sides.
- Which SPA are you using in the ASR1K?
- Which LC are you using in the 6506?
- Have you tried using other fiber?
- Have you tried using a different port or test with a different transceiver?
- Send the command "sh hw-module subslot 0/0 transceiver 0 sta" from the ASR1K.
- Send the commands "show interface tengX/X transceiver". Check if DOM is supported for that transceiver:
DOM
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html#wp41142
10 Gbit Compatibility matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
Bernardo
Hi Bernardo,
We read the link of compatiility and change de transceiver, It work now.
thank
