cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
C1000 route
PQR
C1000 switch support floating routes?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
6 RESPUESTAS 6
 This switch is essentially a layer2 switch and will not support routing.
"Cisco® Catalyst® 1000 Series Switches are fixed managed Gigabit Ethernet and Fast Ethernet enterprise-class Layer 2 switches designed for small businesses and branch offices."
So, this switch support basic routing right?
Static routes with floating route
Yes correct
Thanks!!
You are so welcome
