el 06-21-2024 01:38 AM
Hi community,
I have a doubt about upgrading a switch Cisco Catalyst 9400. Beside to the software image upgrade, the Release Notes say “ROMMON and CPLD version upgrade process must be completed after upgrading the software image.”. Is this true? If so, where can I find the ROMMON and CPLD images/files? I searched in the Software Download page and there are only software images.
This is the link with the information:
It seems CPLD must be upgrade:
For the ROMMON, I am a little confused:
You can upgrade the ROMMON before, or, after upgrading the software version. If a new ROMMON version is available for the software version you are upgrading to, proceed as follows:
Upgrading the ROMMON in the primary SPI flash device
This ROMMON is upgraded automatically. When you upgrade from an existing release on your switch to a later or newer release for the first time, and there is a new ROMMON version in the new release, the system automatically upgrades the ROMMON in the primary SPI flash device, based on the hardware version of the switch.
Upgrading the ROMMON in the golden SPI flash device
You must manually upgrade this ROMMON. Enter the upgrade rom-monitor capsule golden switch command in privileged EXEC mode.
Maybe someone with experience with this type of upgrades can shed some light here.
Thanks in advance,
Julián
¡Resuelto! Ir a solución.
el 07-01-2024 12:35 AM
Hi Leo,
One more doubt. When you upgrade the CPLD there is an inconsistency between the CPLD version of the supervisors, and the CPLD version of the line cards, also docummented in the upgrade guide:
When performing the CPLD version upgrade as shown, the show platform command can be used to confirm the CPLD version after the upgrade. This command output shows the CPLD version on all modules. However, the CPLD upgrade only applies to the supervisors, not the line cards. The line cards CPLD version is a cosmetic display. After the upgrade is completed in a high availability setup, the supervisors will be upgraded, but the line cards will still show the old CPLD version. The version mismatch between the supervisors and line cards is expected until a chassis reload.
To fix this cosmetic error, you must reload the switch chassis. Then,
1. What is the command to reload de switch chassis? Just "reload"?
2. And, when you reload the switch chassis, is there a reload of the line cards? If so, I guess there will be service interruption.
Julián
el 07-01-2024 04:08 AM
"reload" command.
Yes, all line cards will reboot.
06-25-2024 12:47 AM - editado 06-25-2024 01:32 AM
CPLD, FPGA are different components of switch, router, WLC, AP.
@Georg Pauwen wrote:
the ROMMON ... is upgraded automatically
Not all the time.
For example, a router upgrading from 17.3.X (and earlier) to 17.9.X will involve an automatic ROMMON upgrade, ROMMON version 17.7(1r). However, a router upgrading from 17.3.X (and earlier) to 17.12.X will fail (boot-crash-loop) because Cisco has deliberately hidden the information that routers need to upgrade to an intermediate version first, like 17.9.X, before making a jump to 17.12.X. This behaviour is either a bug or a feature, i. e. That 17.12.X does not have ROMMON version 17.7(1r) rolled in.
The information about an intermediate version is not found in any 17.11.X or 17.12.X Release Notes. I spent about 45 minutes trawling different 17.12.X Release Notes and could not find any information about an "upgrade matrix" or any mention about "17.9.X", 17.7(1r) or 17.7.1r.
06-25-2024 01:01 AM - editado 06-25-2024 01:01 AM
Wow, Cisco makes things very complicated.
I have found other post:
https://community.cisco.com/t5/switching/difference-between-cpld-fpga-and-rommon/td-p/5001395
It says "Now, and only now, can you upgrade the ROMMON to the golden/back up flash", but you say in the other post:
I am very confused.
Julián
06-25-2024 01:17 AM - editado 06-25-2024 02:10 AM
My opinion have not changed about "golden capsule upgrade" and I would never recommend anyone perform a golden capsule upgrade because the risk of bricking the switch is high since Cisco developers do not test their code.
Most important matter is this: ROMMON, CPLD, FPGA, microcode upgrade is mandatory, however, upgrading the golden capsule is optional.
el 06-26-2024 01:18 AM
Hi Leo,
Do you say that upgrading the golden capsule could damage the entire switch? I thought that could damage only the golden capsule, and nothing happens because the switch normally boots from the primary flash.
Julián
el 06-26-2024 01:33 AM
If the golden capsule is coded incorrectly, it can-and-will brick the switch.
el 06-26-2024 01:39 AM
Hi community,
Looking at the official documentation, for upgrading the switch there is no need to jump to intermediate versions if I want to upgrade from for example IOS-XE 17.3.x to 17.9.x, the document say nothing about intermediate versions:
For the downgrade, the document says the following:
From 17.9.x to 17.8.x. What if I want to downgrade from 17.9.x to 17.3.x? Can I do it directly? If not, do I need to downgrade from 17.9.x to 17.8.x, then from 17.8.x to 17.7.x, and so on until from 17.4.x to 17.3.x?
Julián
el 06-26-2024 01:48 AM
- Why do you want to downgrade such a way back ?
M.
el 06-26-2024 03:47 AM
Really that doesn't solve my question.
Julián
el 06-26-2024 02:50 AM
Catalyst 9k switches will support direct upgrade from 17.3.X to 17.9.X and 17.12.X and there is no need to go an intermediate version.
el 06-26-2024 03:49 AM
Hi Leo,
That's for the upgrade. But the downgrade can be done directly or going through intermediate versions?
Julián
el 06-26-2024 04:03 AM
Direct downgrade is supported.
el 06-26-2024 04:47 AM
Thank you very much Leo.
Julián
el 06-26-2024 04:08 AM
If still unsure, get the company who's providing the TAC support to conduct a firmware upgrade.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
