cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Enable ssh V2
alexisbonilla84
It is possible to enable SSH V2 on swicht catalyst 2960X
Switch Ports    Model                            SW Version                  SW Image
* 1 52             WS-C2960X-48LPS-L   15.2(4)E8                    C2960X-UNIVERSALK9-M
3 SOLUCIONES ACEPTADAS
Soluciones aceptadas
M02@rt37
Hello @alexisbonilla84;
configure terminal
ip ssh version 2
It is recommended to use a modulus size for RSA Keys of at least 2048 bits for stronger security (min value for ssh v2).
Best regards
Ver la solución en mensaje original publicado
Julio E. Moisa
Yes it is supported.
enable
configure terminal
ip domain-name <company domain>
crypto key generate rsa 1024 or higher
ip ssh version 2
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
according to cisco doc.
Ver.2 is by default enable
"""The configuration for the SSH Version 2 server is similar to the configuration for SSH Version 1. The
ip ssh version command defines the SSH version to be configured. If you do not configure this command, SSH by default runs in compatibility mode; that is, both SSH Version 1 and SSH Version 2 connections are honored.
SSH Version 1 is a protocol that has never been defined in a standard. If you do not want your device to fall back to the undefined protocol (Version 1), you should use the ip ssh version command and specify Version 2. """
3 RESPUESTAS 3
M02@rt37
configure terminal
ip ssh version 2
Best regards
Julio E. Moisa
enable
configure terminal
ip ssh version 2
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
