cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
11
Respuestas
filter routes in ospf for a neighbor
Electronic20
Hello community,
I have a router with hostname BANK, I have 2 segments 192.168.10.0/24 and 192.168.20.0/24 that are learned from 10.10.10.2 by ospf.
but the segments must be learned by neighbor 20.20.20.2,
They are learned on both sides, but 10.10.10.2 sends with a metric of 1, so it has a better preference.
How could my router with hostname BANCO stop receiving segments 192.168.10.0/24 and 192.168.20.0/24 from its neighbor 10.10.10.2?
please your kind help
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
11 RESPUESTAS 11
M02@rt37
Hello @Electronic20,
You could do one of these two methods:
-1- Set a specific OSPF cost for the neighbor 10.10.10.2 higher than the cost towards 20.20.20.2.
router ospf <process_id>
neighbor 10.10.10.2 cost <higher_cost_value>
-2- Use an access list to deny OSPF routes from 10.10.10.2. Apply that ACL under OSPf process to filter routes from 10.10.10.2.
access-list <acl_number> deny <ip>
access-list <acl_number> permit any
distribute-list <acl_number> in <interface>
Best regards
Hi M02@rt37 ,
I got confused on an IP, I show the configuration:
router ospf 10
router id 1.1.1.1
interface vlan 10
ip add 10.10.10.3 255.255.255.0
ip ospf 10 area 0
neighbor 1: 10.10.10.1
neighbor 2: 10.10.10.2
network 192.168.10.0/24 and network 192.168.20.0/24 learn of 10.10.10.1 have cost 1
but, the 192.168.10.0/24 and 192.168.20.0/24 must be learned by the neighbor 10.10.10.2
In that scenario, how could these routes be learned by 10.10.10.2?
I can't modify that configuration:
and If I apply the second option it would modify both neighbors
your kind support
OK @Electronic20
Have you got a draw of your topology?
In your first post you talk about neighbor 20.20.20.2 ? 10.10.10.2 in fact? Neighbor 10.10.10.1 and .2 are then throught the same interface ?
Best regards
hi M02@rt37 ;
Thanks @Electronic20,
On SW-L3-3 interface vlan 10 add ip ospf cost 50 command.
This command allows you to manually override this automatic calculation and set a specific cost for the OSPF interface. This can be useful for influencing OSPF route selection without changing the actual bandwidth of the interface.
Best regards
but it would affect SW L3-2 and SW L3-3 on routes 192.168.10.0/24 and 192.168.20.0/24
I send you message check it
M02@rt37
@Electronic20
You could use ip ospf cost command on the interface's remote router.
https://study-ccna.com/ospf-cost-metric/#:~:text=The%20Cost%20formula%20is%20reference,Mbps%20%2F%2010%20Mbps%20%3D%2010.
Best regards
Hello @Electronic20
Great you find the issue ! Possible to share the solution on a post ? That could help others...
Thanks a lot.
Best regards
Hello M02@rt37
The solution I wanted was not found.
The scenario had to be changed taking a point to multipoint scenario.
Ok @Electronic20
Thanks for you feedback.
Best regards
