cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Infrastructure Security Question.
davidcriollo
Why?
As far as I know. To use the local credential I need the command #Login Local which in this case it is not there.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
M02@rt37
Hello @davidcriollo
Because aaa new model is configured then login local command is not available under lines vty and con. By default, the command login authentication default is configured since aaa new model is configured. So you need the creds username and password enter in local.
Best regards
Ver la solución en mensaje original publicado
5 RESPUESTAS 5
M02@rt37
Hello @davidcriollo
Best regards
When you apply aaa new model
By defualt the login auth of vty will change to use default method of aaa.
I thinking about command show you what really apply to vty.
But let me check this command.
Update you tomorrow
MHM
@MHM Cisco World @davidcriollo
#show run all
Best regards
You sure' I try this before there is nothing appear as I remember.
MHM
sorry even the command I think about is not showing the login auth default under vty
the show run all <<- as I mention this not show the login auth
and this command in my mind also not show the default
If I get something I will update you
MHM
