cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
ip route vrf MYVRF
josebash
I am having some problems with Spectrum and DHCP.
I have this Cisco Asr1001.
I have  a few VRFs
My problem is that Spectrums changes its gateway every few months, and I must manually put it into my router.
#this doesn't work
ip route vrf MYVRF 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 DHCP
becomes this in the sh run =>   ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 DHCP
#This works
ip route vrf MYVRF 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 76.82.101.1
interface GigabitEthernet0/0/0
description TO-ISP
ip vrf forwarding ISP
ip address dhcp
ip mtu 1472
ip nat outside
ip tcp adjust-mss 1360
negotiation auto
How can I use "ip route vrf to get the default gateway from Spectrum DHCP?
I can't find the answer online. Can someone help me out, please?
Thanks in advance.
4 RESPUESTAS 4
balaji.bandi
#This works
when the DHCP IP get you will know the DHCP gateway also ? if so you can run EEM Script when the IP changed
remove the Route and add route with new IP ? (is this something works for you - that is only thing i can think of ?)
BB
Two things
1-it is bug
Or
2-the server send default route and your router add it in global, to check this point run debug ip routing and see when the route is add.
MHM
if the server send this default route you can make Router not ask Op121 from the server
MHM
r.heitmann
well, I can't explain why, but In my lab it's working in my day by day setup well using this configuration:
* without "vrf"-option at the "ip route" command
interface GigabitEthernet1
vrf forwarding INTERNET
ip address dhcp
ip nat outside
negotiation auto
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1 dhcp
Looking at the routing-table:
* "distance" = 254 means by DHCP (normal static routes would have distance=1)
#show ip route vrf INTERNET 0.0.0.0
Routing Table: INTERNET
Routing entry for 0.0.0.0/0, supernet
Known via "static", distance 254, metric 0, candidate default path
Routing Descriptor Blocks:
* 192.168.22.1
Route metric is 0, traffic share count is 1
R1C-A#show dhcp lease
Temp IP addr: 192.168.22.112 for peer on Interface: GigabitEthernet1
Temp sub net mask: 255.255.255.0
DHCP Lease server: 192.168.22.1, state: 5 Bound
DHCP transaction id: 1CA1
Lease: 72000 secs, Renewal: 36000 secs, Rebind: 63000 secs
Temp default-gateway addr: 192.168.22.1
Next timer fires after: 00:35:59
Retry count: 0 Client-ID: cisco-0050.56c9.6ca9-Gi1
Client-ID hex dump: 636973636F2D303035302E353662392E
Hostname: R1C-A
