cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
802.1X and MAC option on SG200 switch
Julian Ortiz
Hi community,
I am configuring a SG200 switch for integration with a NAC, I want to authenticate users (802.1X) and phones (MAC), so I need to configure ports with "802.1X and MAC" option. According to the switch guide this is possible
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb988-802-1x-port-authentication-configuration-on-cisco-200-300-se.html
But in my switch I don't find this option:
The guide is for version 1.3.0.62, and the switch has version 1.3.7.18.
Any idea?
Julián
6 RESPUESTAS 6
balaji.bandi
Small model like 200 does not support that feature i guess : (datasheet shows only 802.1x)
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/data_sheet_c78-667827.html
BB
Yes,
Documentation is confusing, because 802.1X Port Authentication Configuration on Cisco 200/300 Series Managed Switches says Applicable Devices: SF/SG 200 and SF/SG 300 Series Managed Switches.
Sometime Cisco documents are not updated as expected. (if you verify with other document and you have device which do not have that option) - that indicates that this feature not supported.
For Clarity you can call SMB TAC case and ask - https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
BB
that weird
open TAC for this case
MHM
that wired?
doc. you share mention 200 series but the option not appear.
that weird and also the ver. you run higher.
anyway open TAC to more sure that is platform limitation or it bug
MHM
