cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
New C9300L-48P-4X enter to rommon mode since first power on
Hi  Everyone !!
we have a new C9300L-48P-4X ,  since the first time we powered it on went in rommon mode, after running boot command in rommon mode switch reload fine.
The original version  was 17.7.X and we upgraded to 17.9.3 but when switch reload to finish upgrade process once again enter in rommon mode.
we tried the following:
no boot system
boot system flash:packages.conf
no boot manual
write memory
reload
but once again switch enter in  rommon mode even with option "no boot manual".
We have to type boot in rommon mode so that switch reload correctly.
I show the following info as reference.
SW-10#sh boot
Switch 1
Current Boot Variables:
BOOT variable = flash:packages.conf;
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
SW-10#
10#show romvar
ROMMON variables for Active Switch
ABNORMAL_RESET_COUNT=0
AUTO_SWITCH_CONSOLE_DISABLE=0
BAUD=9600
BOARDID=28768
BOOT=flash:packages.conf;
BSI=0
CONSOLE_MIRRORING_DISABLE=0
DC_COPY=yes
MAC_ADDR=E4:62:C4:7F:BF:00
MANUAL_BOOT=no
MODEL_NUM=C9300L-48P-4X
MODEL_REVISION_NUM=D0
MOTHERBOARD_ASSEMBLY_NUM=73-102170-04
MOTHERBOARD_REVISION_NUM=C0
MOTHERBOARD_SERIAL_NUM=FOC26502Q7Q
RANDOM_NUM=1887610756
RET_2_RCALTS=
RET_2_RTS=16:43:55 CST Thu Jul 27 2023
ROMMON_AUTOBOOT_ATTEMPT=3
ReloadReason=Image Install RET_2_RCALTS=1690487718
SWITCH_IGNORE_STARTUP_CFG=0
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=FOC2653Y865
TEMPLATE=access
USB_DISABLE=0
VERSION_ID=V05
SW-10#
Any recommendation to clear this issue?
4 RESPUESTAS 4
M02@rt37
Hello @filiberto.aguirre,
Check your config-register command--- it should be config-register 0x2102
Best regards
Hi @filiberto.aguirre
 I advise you to upgrade the rommon
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-9/release_notes/ol-17-9-9300/upgrading_the_switch_software.html#concept_ycv_jdf_3mb
As you have the command "no boot manual" and "MANUAL_BOOT=no" the switch should not go to rommon after reload anymore.
If the switch is booting with the command boot this means the IOS is ok but something is not right with the switch. In case you upgrade the rommon and you still see this behavior I would remmmend to replace the switch.
Hi Flavio,
Thanks for your recommendations, I show you the results  after upgrading.
SW-10#upgrade rom-monitor capsule golden switch active r0
This operation will reload the switch and take a few minutes to complete. Do you want to proceed (y/n)? [confirm]y
SW-10#
*Jul 28 10:25:34.421: %IOSXEBOOT-4-CAPSULE_UPGRADE: (local/local): ### Fri Jul 28 10:25:34 CST 2023 Restarting system to start capsule upgrade ####
Chassis 1 reloading, reason - System error occurred      -----------------> ????
Jul 28 10:25:37.557: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting:
Jul 28 10:25:38.634: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting:
Initializing Hardware...
Updating Golden from Primary
Starting BIOS update
Insyde H2OFFT (Flash Firmware Tool) Version (SEG) 200.00.00.02-Beta
Copyright (C) 2018 Insyde Software Corp. All Rights Reserved.
Platform Name: Harrisonville
Current Version: HRV.05.10.12.0026
Update Version: HRV.05.10.12.0026
Updating Block at FFFFF000h 100%
BIOS update successful
System Bootstrap, Version 17.9.1r, RELEASE SOFTWARE (P)
Compiled Thu 05/05/2022 9:24:36.57 by rel
Current ROMMON image : Primary
Last reset cause : LocalSoft
C9300L-48P-4X platform with 8388608 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf] (interrupted)
switch:
I guess there is something wrong with switch's hardware.
regards
If you can proceed with RMA, I recommend.
