el 12-14-2023 12:37 PM
I am having this situation on an Interface connected to a VMware Host, where internally is configured a VMSwitch for MGMT.
Sending 1000, 100-byte ICMP Echos to 172.X.X.200, timeout is 2 seconds:
el 12-14-2023 01:52 PM
post this output : show interface te1/0/6
ML-SW-HIVM-01#sh int te1/0/6
TenGigabitEthernet1/0/6 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is cc36.cf29.0006 (bia cc36.cf29.0006)
Description: Uplink-HV2-Vmnic2
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, media type is 100/1000/2.5G/5G/10GBaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:12, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 16000 bits/sec, 17 packets/sec
5597 packets input, 716370 bytes, 0 no buffer
Received 1061 broadcasts (1048 multicasts)
0 watchdog, 1048 multicast, 0 pause input
415121 packets output, 129100928 bytes, 0 underruns
Output 201126 broadcasts (135054 multicasts)
0 output errors, 0 collisions, 2 interface resets
1048 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
ML-SW-HIVM-01#
ML-SW-HIVM-01#
what vlan exsi and vm host belong to ? 50
what is the outcome from esxi IP address to host sitting inside Linux box ? I am not getting this
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
