cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
15
Respuestas
Packet Loss pattern 9300 to VMnic
santi8809
I am having this situation on an Interface connected to a VMware Host, where internally is configured a VMSwitch for MGMT.
Sending 1000, 100-byte ICMP Echos to 172.X.X.200, timeout is 2 seconds:
15 RESPUESTAS 15
M02@rt37
Hello @santi8809
Assess the load on the VMware host. High resource utilization might affect its ability to respond to ping requests promptly.
Best regards
This is a new Setup, there is no utilization. It only happens with the IP address asigned on the VMKernels Networks
That normal it can CoPP of SW drop icmp packet when it reach specific limit.
MHM
share the output of this
Device# show policy-map control-plane
MHM
#show policy-map control-plane
Control Plane
Service-policy input: system-cpp-policy
Class-map: system-cpp-police-ios-routing (match-any)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: none
police:
rate 13000 pps, burst 3173 packets
conformed 27748276 bytes; actions:
transmit
exceeded 0 bytes; actions:
drop
Class-map: system-cpp-police-ios-feature (match-any)
0 packets, 0 bytes
Match: none
police:
rate 6000 pps, burst 1464 packets
conformed 279979375 bytes; actions:
transmit
drop
Class-map: system-cpp-police-data (match-any)
0 packets, 0 bytes
Match: none
police:
rate 750 pps, burst 183 packets
conformed 53325891 bytes; actions:
transmit
drop
Class-map: system-cpp-police-sys-data (match-any)
0 packets, 0 bytes
Match: none
police:
rate 250 pps, burst 61 packets
conformed 0 bytes; actions:
transmit
drop
Class-map: system-cpp-police-sw-forward (match-any)
0 packets, 0 bytes
Match: none
police:
rate 1000 pps, burst 244 packets
conformed 11532 bytes; actions:
transmit
drop
Class-map: system-cpp-police-multicast (match-any)
0 packets, 0 bytes
Match: none
police:
rate 500 pps, burst 122 packets
transmit
drop
Class-map: system-cpp-police-multicast-end-station (match-any)
0 packets, 0 bytes
Match: none
police:
rate 2000 pps, burst 488 packets
conformed 7628298 bytes; actions:
transmit
drop
Class-map: system-cpp-police-punt-webauth (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-l2-control (match-any)
0 packets, 0 bytes
Match: none
police:
conformed 11054141 bytes; actions:
transmit
drop
Class-map: system-cpp-police-stackwise-virt-control (match-any)
0 packets, 0 bytes
Match: none
police:
rate 8000 pps, burst 1953 packets
transmit
drop
Class-map: system-cpp-police-routing-control (match-any)
0 packets, 0 bytes
Match: none
police:
rate 5500 pps, burst 1342 packets
conformed 155024 bytes; actions:
transmit
drop
Class-map: system-cpp-police-system-critical (match-any)
0 packets, 0 bytes
Match: none
police:
conformed 12512 bytes; actions:
transmit
drop
Class-map: system-cpp-police-l2lvx-control (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-topology-control (match-any)
0 packets, 0 bytes
Match: none
police:
conformed 16539111 bytes; actions:
transmit
drop
Class-map: system-cpp-police-dot1x-auth (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-protocol-snooping (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-dhcp-snooping (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-forus (match-any)
0 packets, 0 bytes
Match: none
police:
rate 4000 pps, burst 976 packets
conformed 219013654 bytes; actions:
transmit
drop
Class-map: system-cpp-default (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-high-rate-app (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: system-cpp-police-ewlc-control (match-any)
0 packets, 0 bytes
Match: none
police:
transmit
drop
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
Also share this
Show controllers cpu-interface
MHM
#Show controllers cpu-interface
queue retrieved dropped invalid hol-block
Routing Protocol 1253 0 0 0
L2 Protocol 65759 0 0 0
sw forwarding 103 0 0 0
broadcast 214611 0 0 0
icmp gen 0 0 0 0
icmp redirect 0 0 0 0
logging 0 0 0 0
rpf-fail 0 0 0 0
DOT1X authentication 0 0 0 0
Forus Traffic 34026 0 0 0
Forus Resolution 1725852 0 0 0
Inter FED 0 0 0 0
L2 LVX control 0 0 0 0
EWLC control 0 0 0 0
EWLC data 0 0 0 0
L2 LVX data 0 0 0 0
Openflow 0 0 0 0
Topology control 182175 0 0 0
Proto snooping 0 0 0 0
DHCP snooping 0 0 0 0
Transit Traffic 0 0 0 0
Multi End station 44343 0 0 0
Webauth 0 0 0 0
High rate app 0 0 0 0
Exception 0 0 0 0
System Critical 0 0 0 0
NFL sampled data 0 0 0 0
Low latency 0 0 0 0
EGR exception 0 0 0 0
Stackwise Virtual OOB 0 0 0 0
Multicast data 0 0 0 0
Gold packet 38 0 0 0
Every thing is OK
The SW CPU and it queue dont drop traffic.
Show interface x
Check the output drop counter
MHM
sh int te1/0/2
TenGigabitEthernet1/0/2 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is cc36.cf29.0002 (bia cc36.cf29.0002)
Description: Uplink-HV1-Vmnic7
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, media type is 100/1000/2.5G/5G/10GBaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:17, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:02:03
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6000 bits/sec, 10 packets/sec
1629 packets input, 144884 bytes, 0 no buffer
Received 157 broadcasts (8 multicasts)
0 watchdog, 8 multicast, 0 pause input
491 packets output, 69308 bytes, 0 underruns
Output 36 broadcasts (73 multicasts)
8 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Hi friend can you share the output of this command
9300_1#show plat hardware fed switch active qos queue stats internal cpu policer
sorry for late reply
thanks
MHM
CPU Queue Statistics
(default) (set) Queue Queue
QId PlcIdx Queue Name Enabled Rate Rate Drop(Bytes) Drop(Frames)
0 11 DOT1X Auth Yes 1000 1000 0 0
1 1 L2 Control Yes 2000 2000 0 0
2 14 Forus traffic Yes 4000 4000 0 0
3 0 ICMP GEN Yes 750 750 0 0
4 2 Routing Control Yes 5500 5500 0 0
5 14 Forus Address resolution Yes 4000 4000 0 0
6 0 ICMP Redirect Yes 750 750 0 0
7 16 Inter FED Traffic Yes 2000 2000 0 0
8 4 L2 LVX Cont Pack Yes 1000 1000 0 0
9 19 EWLC Control Yes 13000 13000 0 0
10 16 EWLC Data Yes 2000 2000 0 0
11 13 L2 LVX Data Pack Yes 1000 1000 0 0
12 0 BROADCAST Yes 750 750 0 0
13 10 Openflow Yes 250 250 0 0
14 13 Sw forwarding Yes 1000 1000 0 0
15 8 Topology Control Yes 13000 13000 0 0
16 12 Proto Snooping Yes 2000 2000 0 0
17 6 DHCP Snooping Yes 500 500 0 0
18 13 Transit Traffic Yes 1000 1000 0 0
19 10 RPF Failed Yes 250 250 0 0
20 15 MCAST END STATION Yes 2000 2000 0 0
21 13 LOGGING Yes 1000 1000 0 0
22 7 Punt Webauth Yes 1000 1000 0 0
23 18 High Rate App Yes 13000 13000 0 0
24 10 Exception Yes 250 250 0 0
25 3 System Critical Yes 1000 1000 0 0
26 10 NFL SAMPLED DATA Yes 250 250 0 0
27 2 Low Latency Yes 5500 5500 0 0
28 10 EGR Exception Yes 250 250 0 0
29 5 Stackwise Virtual OOB Yes 8000 8000 0 0
30 9 MCAST Data Yes 500 500 0 0
31 3 Gold Pkt Yes 1000 1000 0 0
* NOTE: CPU queue policer rates are configured to the closest hardware supported value
CPU Queue Policer Statistics
Policer Policer Accept Policer Accept Policer Drop Policer Drop
Index Bytes Frames Bytes Frames
0 70662468 553388 0 0
1 38064542 221811 0 0
2 208992 3264 0 0
3 2584 38 0 0
4 0 0 0 0
5 0 0 0 0
6 0 0 0 0
7 0 0 0 0
8 50274798 468879 0 0
9 0 0 0 0
10 0 0 0 0
11 0 0 0 0
12 0 0 0 0
13 11650 104 0 0
14 402707134 6207577 0 0
15 9942556 107046 0 0
16 0 0 0 0
17 0 0 0 0
18 0 0 0 0
19 0 0 0 0
Second Level Policer Statistics
20 88548332 693954 0 0
21 483323808 6868115 0 0
Policer Index Mapping and Settings
level-2 : level-1 (default) (set)
PlcIndex : PlcIndex rate rate
20 : 1 2 8 13000 13000
21 : 0 4 7 9 10 11 12 13 14 15 6000 6000
Second Level Policer Config
level-1 level-2 level-2
QId PlcIdx PlcIdx Queue Name Enabled
0 11 21 DOT1X Auth Yes
1 1 20 L2 Control Yes
2 14 21 Forus traffic Yes
3 0 21 ICMP GEN Yes
4 2 20 Routing Control Yes
5 14 21 Forus Address resolution Yes
6 0 21 ICMP Redirect Yes
7 16 - Inter FED Traffic No
8 4 21 L2 LVX Cont Pack Yes
9 19 - EWLC Control No
10 16 - EWLC Data No
11 13 21 L2 LVX Data Pack Yes
12 0 21 BROADCAST Yes
13 10 21 Openflow Yes
14 13 21 Sw forwarding Yes
15 8 20 Topology Control Yes
16 12 21 Proto Snooping Yes
17 6 - DHCP Snooping No
18 13 21 Transit Traffic Yes
19 10 21 RPF Failed Yes
20 15 21 MCAST END STATION Yes
21 13 21 LOGGING Yes
22 7 21 Punt Webauth Yes
23 18 - High Rate App No
24 10 21 Exception Yes
25 3 - System Critical No
26 10 21 NFL SAMPLED DATA Yes
27 2 20 Low Latency Yes
28 10 21 EGR Exception Yes
29 5 - Stackwise Virtual OOB No
30 9 21 MCAST Data Yes
31 3 - Gold Pkt No
CPP Classes to queue map
PlcIdx CPP Class : Queues
0 system-cpp-police-data : ICMP GEN/ BROADCAST/ ICMP Redirect/
10 system-cpp-police-sys-data : Openflow/ Exception/ EGR Exception/ NFL SAMPLED DATA/ RPF Failed/
13 system-cpp-police-sw-forward : Sw forwarding/ LOGGING/ L2 LVX Data Pack/ Transit Traffic/
9 system-cpp-police-multicast : MCAST Data/
15 system-cpp-police-multicast-end-station : MCAST END STATION /
7 system-cpp-police-punt-webauth : Punt Webauth/
1 system-cpp-police-l2-control : L2 Control/
2 system-cpp-police-routing-control : Routing Control/ Low Latency/
3 system-cpp-police-system-critical : System Critical/ Gold Pkt/
4 system-cpp-police-l2lvx-control : L2 LVX Cont Pack/
8 system-cpp-police-topology-control : Topology Control/
11 system-cpp-police-dot1x-auth : DOT1X Auth/
12 system-cpp-police-protocol-snooping : Proto Snooping/
6 system-cpp-police-dhcp-snooping : DHCP Snooping/
14 system-cpp-police-forus : Forus Address resolution/ Forus traffic/
5 system-cpp-police-stackwise-virt-control : Stackwise Virtual OOB/
16 system-cpp-default : Inter FED Traffic/ EWLC Data/
18 system-cpp-police-high-rate-app : High Rate App/
19 system-cpp-police-ewlc-control : EWLC Control/
20 system-cpp-police-ios-routing : L2 Control/ Topology Control/ Routing Control/ Low Latency/
21 system-cpp-police-ios-feature : ICMP GEN/ BROADCAST/ ICMP Redirect/ L2 LVX Cont Pack/ Proto Snooping/ Punt Webauth/ MCAST Data/ Transit Traffic/ DOT1X Auth/ Sw forwarding/ LOGGING/ L2 LVX Data Pack/ Forus traffic/ Forus Address resolution/ MCAST END STATION / Openflow/ Exception/ EGR Exception/ NFL SAMPLED DATA/ RPF Failed/
balaji.bandi
You need to provide more information here :
1. what is the Full model of the switch ?
2. what IOS Xe code running on it ?
3. what interface connected to esxi ? is the Bundle interface or single ? can you post the configuration ?
4. what Esxi version ?
5. what interface card you using on esxi ? what speed ?
6. show interface x/x (from switch help us)
7. the Ping you doing from Switch to VM host or exsi ?
8. what is the VM host windows Server or Linux ?
BB
  1. what is the Full model of the switch ? C9300X-48HX
  2. what IOS Xe code running on it ?  17.09.04a CAT9K_IOSXE
  3. what interface connected to esxi ? is the Bundle interface or single ? can you post the configuration ? Single
  4. what Esxi version ? 8.0.2
  5. what interface card you using on esxi ? what speed ? 10GB (Additional CARD)
    01#sh run int te1/0/6
    Building configuration...
    Current configuration : 149 bytes
    interface TenGigabitEthernet1/0/6
    description Uplink-HV2-Vmnic2
    switchport trunk allowed vlan 1,50
    switchport mode trunk
    end
  7. the Ping you doing from Switch to VM host or exsi ? From Switch to IP configured on ESXI Host
  8. what is the VM host windows Server or Linux ? Linux
post this output : show interface te1/0/6
what vlan exsi and vm host belong to ?
what is the outcome from esxi IP address to host sitting inside Linux box ?
check couple of settings on esxi :
https://kb.vmware.com/s/article/2039495
https://kb.vmware.com/s/article/1004109
BB
