cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
8
Respuestas
Static routing not working
bautiarcangeli
Hello. I have a issue with the static routing. I dont know why it isnt working.I watched many videos to try to solve the problem, I do exactly what videos and posts say. Here is the network, If i send a message from the PC0 to Router0, it is successful but when i send from the PC0 to Router1, it says "failed".
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
M02@rt37
Hello @bautiarcangeli,
Look the second byte:
Then modify interface serial 0/0/0 on Router0 like this:
From Router0, you should ping Router1 interface serial 0/0/0:
Also, on Router1, modify ip route, instead of
configure this:
After that, from PC0 you should be able to ping PC1:
and vice versa.
Best regards
Ver la solución en mensaje original publicado
8 RESPUESTAS 8
ammahend
for packet tracer problem, always share file, makes it easier to help.
-hope this helps-
Thank you, i will share the file
bautiarcangeli
Thats the file in a zip, cant upload it as .pkt. Sorry, this is my first time using community posts
M02@rt37
configure this:
and vice versa.
Best regards
Thank you so much for answering me. Now, it works fine after the changes you said. I have another question, does changing router0 IP to 192.188.1.1 means that it is on the same network as the router1, that its ip is 192.188.1.2? Wouldnt static routing work to connect routers from differents networks? Thank you!!
You're welcome @bautiarcangeli
Interco between R0 and R1 have to be in a same subnet. You should use /30 network, it is sufficient.
Best regards
Ciro G Mele
Level 2
Level 2
Hi,bautiarcangeli
Could you tell me what the IP of PC0 is and on PC0 do you have the default gateway configured?
Thanks.
Ciro Gustavo Mele
Thank you for the answer. The PC0 default gateway is 192.168.101.1, that it is the gigabitethernet ip from the router0. And the IP of PC0 is 192.168.101.10. Thank you
