el 09-27-2023 03:27 PM
Hi Community,
I have 2 firepower in HA model 2110, and it has the following alerts, what does it mean and what could I execute to make these alerts disappear?
Another issue, once a FW failed, a change was made and it seems to me that when the HA was replaced they only placed the active IP and not the Standby, how could I place the standby IP?
el 09-27-2023 04:59 PM
that indicated those interface not seeing any traffic, so check the VLAN tagged on the switch or SVI any issue ?
Since you mentioned this was happening after replacing the FW failed one - which one you replace standby or active one ?
if you replaced active one this might have failed over to standby, try failover back and check (if that fix the issue ?)
or this may be errors were there before ?
el 09-27-2023 07:50 PM
It was validated that the ports mentioned and the vlan have traffic, I don't know why those alarms appear.
We just realized it a few days ago.
The Standby was replaced.
In any case, how can I eliminate these alarms? and put IP to the firepower backup? since they have put it without IP.
The 2 firepower are in HA.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
