Kelly4
Hello everyone! Here are the release notes for the most recent updates we’ve made to Duo.
You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
What’s in this release?
New features, enhancements, and other improvements
New and updated applications
Bug fixes
See all bug fixes
Added setting to allow Help Desk role administrators to send enrollment emails
  • Introduced a setting that allows Help Desk administrators to send enrollment emails to users from the Users page in the Admin Panel. To grant this permission, go to Settings > Help Desk in the Admin Panel and select “Allow admins with Help Desk role to send enrollment emails.”
Changes to Flash policy configuration options following Adobe Flash Player end of support
  • Following Adobe’s end of support for Adobe Flash Player in December 2020, Duo has updated its Flash plugin policy configuration options for all new Flash policies created after June 3, 2021.
  • New Flash policies will no longer have the configuration options for “Warn users when their Flash plugin is out of date” or “Block them if it’s more than [X timeframe] out of date.” This change does not impact any existing policies set to warn or block if out of date.
  • Refer to this Duo Knowledge Base article for more information.
Operating Systems policy configuration options now include all minor and patch versions of Android, iOS, and macOS
  • The listed static versions for Android, iOS, and macOS in the Admin Panel OS policy editor now include all minor and patch versions of those operating systems as configuration options.
Windows 10 version 1909 marked end-of-life in Operating Systems policy
  • Windows 10 version 1909 (build number 10.0.18363.*) is now end-of-life for the purposes of OS policy as of June 8, 2021.
Improved performance when downloading the Telephony Log
  • Significantly shortened the time it takes to download the Telephony Log via the Duo Admin Panel by improving performance.
Duo Device Health application for macOS version 2.14.0.0 and version 2.14.1.0 released
  • Version 2.14.0.0:
    • Minor improvements and enhancements.
  • Version 2.14.1.0:
    • Fixed detection of Bitdefender Endpoint Security.
Duo Device Health application for Windows version 2.14.0 released
Duo Mobile for iOS version 3.57.0 released
  • Various behind-the-scenes improvements and minor bug fixes to enhance your authentication experience.
Duo Mobile for Android version 3.57.0 released
Bug fixes
  • Enhancements for Directory Sync:
    • For OpenLDAP syncs, directory configurations with directory groups can no longer be saved without adding entrydn values. Added better error reporting during sync if a directory group has no entrydn value.
    • For OpenLDAP and Active Directory syncs, added error reporting if a selected group cannot be found in a directory.
  • Fixed an issue that sometimes prevented the “Save my email address for next time” checkbox in the Duo Admin Panel login prompt from persisting the administrator’s preference.
  • Fixed a bug on the Admin Panel details page for pending Duo administrator accounts that disabled the “Send email” activation link.
Corbett Enders
Are there release notes for the iOS app?
Kelly4
Hi cenders!
Do you mean Duo Mobile for iOS? Yes, we post both iOS and Android Duo Mobile release notes in the running release notes posts in this category (the same information appears in the App Store and Play Store with each release). For version 3.57.0, please see the following section:
Hope this helps!
Corbett Enders
That doesn’t contain any specifics about what is changed or fixed in the app updates.
Kelly4
Hi cenders,
Ah, thanks for asking about this. When the release contains minor bug fixes or minor changes, we do not go into detail. When the release contains larger feature functionality or major bug fixes, we do include that information. With the upcoming redesign of the Duo Mobile app, you may have noticed that the version 3.xx release notes were more likely to be brief recently. That’s because the team has been working hard on the next major release. I hope this helps!
