Kelly4
Hello everyone! Here are the release notes for the most recent updates we’ve made to Duo.
You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
What’s in this release?
New features, enhancements, and other improvements
New and updated applications
Bug fixes
See all bug fixes
Duo Single Sign-On now supports multiple Active Directory authentication sources
  • You can now configure multiple AD authentication sources with Duo Single Sign-On, such as in environments with multiple Active Directory forests where you want to implement SSO.
Duo Network Gateway version 1.6.1 released
  • Fixed issue with dngdns DNS container for RDP to make it pass DNS delegation check performed by Windows Server.
  • Improved logging output for dngdns DNS container for RDP.
  • Fixed issues that treated RDP and SSH internal hostnames as case-sensitive.
  • Offboarding a user now also terminates active SSH and RDP sessions.
DuoConnect public preview release 1.1.1+subzero-2.0.1 for macOS and Windows
  • For macOS:
    • Improved security around authentication procedure for SSH (cookie now delivered via POST instead of GET).
  • For Windows:
    • Fixed issues where Windows Firewall was blocking DuoConnect from making connections.
    • Fixed issue that resulted in some antivirus agents quarantining a necessary DuoConnect executable.
Duo Device Health application version 2.23.0.0 for macOS and version 2.23.0 for Windows released
  • Minor improvements and enhancements.
  • Duo’s code signing certificate has been updated. The new certificate subject name is “Duo Security LLC”.
Duo Mobile for iOS version 4.10.0 released
  • Miscellaneous bug fixes and behind-the-scenes improvements.
Duo Mobile for Android versions 4.10.0 released
Bug fixes
  • Fixed a bug in which deleting the authorizing user for an Azure Active Directory Sync from Azure resulted in an error. Now, the Duo administrator will see a message that reauthorizing Azure is required.
