What's in this release?
Hello everyone! Here are the release notes for our most recent updates to Duo.
Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out. You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
Check out the Guide to Duo End-of-Life and End-of-Support Plans. This guide provides an up-to-date list of current and past end-of-life plans for Duo products.
New features, enhancements, and other improvements
Now generally available: Provision Duo from Cisco Security Cloud Control
Now generally available: Policy Endpoints in the Admin API
- RBFS and RBRD policies can suppress detection of a novel IP address or novel WiFi Fingerprint if the user is authenticating from an IP address on a list of known low-risk IPs defined in the policy.
- To define low-risk IP addresses for RBFS or RBRD, edit the policy of each application protected by RBFS or RBRD in the Duo Admin Panel and specify a list of IP addresses, IP ranges or CIDRs in Add Trusted Networks.
A screen grab of the new Add trusted networks section.
- Optionally specify which IP addresses or ranges are allowed to use your Device API application in Trusted Endpoints > Networks for API Access. If you do not specify any IP addresses or ranges, the Device API application may be accessed from any network.
A screen grab of the new Networks for API access (optional) section.
- As of October 17, Duo operating systems policy will recognize Android 14 as the latest and Android 13 as up-to-date.
New and updated applications
Five new named SAML applications with Duo SSO
- Fixed an issue that would cause the app to crash on macOS 10.15.
- Fixed an issue that prevented the app from launching automatically on reboot.
- Fixed an issue that could cause authentications to fail due to a certificate loading error.
- Fixed an issue that could cause health checks to fail when running inside certain virtual environments.
- Minor security enhancements.
- Miscellaneous bug fixes and behind-the-scenes improvements.
Bug fixes
- Restored the ability of Passwordless WebAuthn credentials registered in Windows to apply across browsers.
