kyleleighavery
Hello everyone! Here are the release notes for our most recent updates to Duo.
Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out. You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
Check out the Guide to Duo End-of-Life and End-of-Support Plans. This guide provides an up-to-date list of current and past end-of-life plans for Duo products.
New features, enhancements, and other improvements
Now generally available: Duo Trust Monitor security event notifications
Now generally available: Duo Authentication Proxy Dashboard
  • The dashboard lets Duo administrators monitor the state of Authentication Proxies from the Duo Admin Panel.
  • The dashboard is compatible with Authentication Proxies running version 6.0.1 or later and configured for SSO, MFA, or directory sync.
Duo Single Sign-On for Generic OpenID Connect (OIDC) Relying Parties now supports OIDC Claim Transformations
  • OIDC Claim Transformations lets you define rules to modify relying party user attributes (claims) mapped to Identity Provider (IdP) attributes.
  • OIDC Claim Transformation rules are useful when an OIDC relying party requires an attribute in a format that isn't provided by your IdP source.
  • The OIDC Claim Transformations feature in the Duo Admin Panel also lets you preview the result of transformation rules.
Duo Single Sign-On for Generic SAML Service Providers now supports preview of Attribute Transformation rules
  • The Attribute Transformation feature in the Duo Admin Panel now lets you preview the result of transformation rules.
New Duo Push Verification endpoint available in the Duo Admin API
  • The new endpoint /verification_push_response enables the Admin API to return the result of a specific verification push.
Mobile Device Biometrics policy now supports disabling fallback to a less secure authentication factor
  • Duo administrators can now choose to disable fallback to the device passcode when biometric verification fails on an authentication device with Duo Mobile.
  • Available in Duo Advantage and Duo Premier.
New and updated applications
Five new named SAML applications with Duo SSO
Duo Authentication Proxy version 6.2.0 released
Duo Desktop for macOS version 6.2.0.0 released
  • Fixed an issue that would prevent the app from automatically launching after being updated or when logging in.
  • Significantly improved the performance of certain security agent checks.
Duo Desktop for Windows 10 and 11 version 6.2.0 released
  • Fixed an issue that would cause automatic updates to the app to get delayed if the system was in sleep or hibernate mode.
Duo Mobile for Android version 4.55.0 released
  • Miscellaneous bug fixes and behind-the-scenes improvements.
Duo Mobile for iOS version 4.55.0 released
Bug fixes
  • Duo administrators with the Help Desk role can now export reports in CSV and JSON format.
