Hello everyone! Here are the release notes for our most recent updates to Duo.
Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out. You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
Check out the Guide to Duo End-of-Life and End-of-Support Plans. This guide provides an up-to-date list of current and past end-of-life plans for Duo products. We expect to reach these milestones by the end of next month:
- Effective March 30, 2024, Duo will no longer support the Duo LDAP cloud service (LDAPS) used to provide two-factor authentication for Cisco ASA, Juniper Networks Secure Access, or Pulse Secure Connect Secure SSL VPN logins.
- Effective March 30, 2024, Duo will no longer support the traditional Duo Prompt. Duo for NetScaler applications are an exception and the EOL date for existing Duo for NetScaler applications has been extended to September 30, 2024.
New features, enhancements, and other improvements
- When a user registers a security key, through either the self-service or the device management portal, or an admin registers a security key through the Duo Admin Panel, they may now see a browser-specific dialogue screen asking them to share the security key's make and model with Duo.
- The user or admin needs to accept this dialogue before they can proceed with registration.
- This action does not share any personal information with Duo.
- The Duo Universal Prompt has built-in automatic authentication method selection behavior that makes it easier for users to access their protected applications by automatically choosing the most-secure factor.
- If automatic selection interferes with a user's authentication experience, Administrators can turn it off for an individual user through the Users section of the Duo Admin Panel or through the Admin API.
The authentication experience setting offers options to enable or disable automatic selection of authentication methods.
- If a user has 7 or more authentication methods available through the Universal Prompt, a new dropdown menu will allow the user to filter by authentication methods available for each specific device.
View with all authentication methods for all devices.
View filtered by device.
- To help Duo Administrators more easily identify which applications need to migrate from the traditional Duo Prompt to the Universal Prompt, the Universal Prompt Progress report in the Admin Panel now has clearer, consolidated tabs.
- Action required contains all applications that may be using the Traditional Prompt
- No action required contains applications already upgraded to the Universal Prompt and unaffected applications.
The Universal Prompt Progress report now shows Action required and No action required tabs.
- The “Risk-Based Policy Assessment” column in the Authentication Log in the Admin Panel now shows Authentication stepped-up instead of User stepped-up when the user is in a stepped-up state due to a previous authentication.
- Entries in the Authentication Log with a detection from Risk-Based Factor Selection are now tagged with a clickable icon in the “Risk-Based Policy Assessment” column that displays a detection sequence.
- The detection sequence helps string together a list of authentication logs from the point where the user is initially stepped-up until they are out of step-up status.
Sequence details showing impacted authentications.
- Duo SSO for NetDocuments now allows Duo admins to configure the length of sessiontimeout used in the SAML token generated by Duo.
New and updated applications
Two new named SAML applications with Duo SSO
- Accessibility improvements.
- Design improvements and minor bug fixes in installer.
- Corrects an issue which caused occasional black or frozen screens during Duo login.
- Adds an optional registry setting ParseUsernameAndDomain which overrides Duo user/domain determination logic by parsing the username provided by the user. Refer to Why might an incorrect username get sent to Duo from a machine joined to Entra ID? for more information.
- Addresses a security vulnerability in which trusted sessions persisted after a reboot (CVE-2024-20301; Cisco Security Advisory).
- Addresses a security vulnerability where the Duo secret key value was logged in plain-text during an application upgrade (CVE-2024-20292; Cisco Security Advisory).
- Corrects an issue where the installer did not secure the Duo registry key so integration credentials could be read by unprivileged users until the registry key was secured by first launch of the application.
- Added collection of information related to the expiration of certificates.
- Session Logouts are now reported when the application is closed.
- Added collection of information related to registration and health reporting performance.
- Miscellaneous bug fixes and behind-the-scenes improvements.
Bug fixes
- Universal Prompt Progress report now lists the Duo Admin Panel - Single Sign-On application under the No action required tab of the Universal Prompt Progress report instead of the Action required tab because it doesn't require intervention.
- An error with message "Invalid Authentication Proxy" no longer occurs in the Authentication Proxy Dashboard in the Admin Panel if an Authentication Proxy was enrolled in and then later removed from SSO.
- The following text has changed in the Administrator Activity report in the Admin Panel:
- “Resend all enroll codes” is now “Resent all enrollment links”
- “Send an enroll code” is now “Sent an enrollment link”
- "Deleted an enroll code" is now “Deleted an enrollment link”
