kyleleighavery
Hello everyone! Here are the release notes for our most recent updates to Duo.
Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out. You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
Check out the Guide to Duo End-of-Life and End-of-Support Plans. This guide provides an up-to-date list of current and past end-of-life plans for Duo products.
New features, enhancements, and other improvements
Now generally available for Advantage and Premier customers: Duo Passport
  • Reduce the number of interactive authentications that end users have to complete by extending "remember me" functionality across all applications.
Exports from the Users section of the Duo Admin Panel include user notes
  • Select the Export button on the Users page and choose from the available export options to download a copy of the user log with notes included.
Policies in Duo Admin Panel defaults to compact view
  • Admin Panel users may select Switch to expanded view on the Policies page to see the old view. Policies will not change between views.
Duo Federal edition integration with Microsoft Entra ID Conditional Access policies now available
  • Duo integration with Microsoft Entra ID (formerly Azure Active Directory or Azure AD) Conditional Access (CA) allows you to set policies that evaluate and control Entra ID user access attempts.
    • Please note that this integration only works with Commercial Entra ID tenants and does not work for Entra ID GCC or GCC-High.
New and updated applications
Two new named SAML applications with Duo SSO
  • There are now named SAML applications to protect Lucid and Dashlane with Duo Single Sign-On (SSO), our cloud identity provider.
  • Reminder: Duo Access Gateway reached the last date of support on October 26, 2023. The DAG end-of-life milestone scheduled for March 30, 2024, has been canceled. At this time, existing DAG applications will continue to work after March 30, 2024. Please see the Guide to Duo Access Gateway end of life for more details.
Duo Desktop macOS version 6.8.0.0 released
  • Improved logging when registering devices.
  • Minor improvements and enhancements.
Duo Desktop macOS public beta version 6.7.1.0 released
Duo Desktop Windows 10 and 11 version 6.8.0 released
  • Fixed an issue preventing active security agents from being captured when running the support tool.
Duo Desktop Windows public beta version 6.7.1 released
Duo Mobile for Android version 4.66.0 released
  • Miscellaneous bug fixes and behind-the-scenes improvements.
Duo Mobile for iOS version 4.66.0 released
Bug fixes
  • Altered the current named GitLab SaaS integration to support email, first name and last name mapped attributes.
  • A code fix has been implemented to ensure that the certificate information is correctly retrieved and populated from an XML URL during the setup of a generic SAML integration. This fix specifically addresses issues encountered with Crowdstrike metadata, as well as other potential URLs that provide SAML configuration data.
  • Fixed bug where activity logs were not correctly recording when a given directory group was moved from one directory sync to another.
    • All directory sync group change activity logs now record synced group names as they appear in the directory, rather than with a suffix identifying the directory sync they belong to.
kyleleighavery
6/26/24 added clarifying sub-bullet to Duo Federal edition entry.
DuoKristina
Edited to add label.
