Rick Wong
Hello everyone! Here are the release notes for our most recent updates to Duo.
Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out. You can subscribe to notifications for new release notes by following the process described here. If you have any questions about these changes, please comment below.
Check out the Guide to Duo End-of-Life and End-of-Support Plans. This guide provides an up-to-date list of current and past end-of-life plans for Duo products.
New Features and Enhancements
Now in Public Preview: Duo SSO Routing Rules
  • You can now use multiple SAML and Active Directory sources at the same time.
  • Configure routing between sources based on user's domain, IP space, or application being accessed.
 Now available in Duo’s Federal Editions: Duo Two-Factor Authentication for Microsoft Entra ID External Authentication Methods (EAM)
  • This integration is identical to that of the EAM integration in Duo’s commercial editions.
  • This integration works with Azure’s Commercial and GCC and does not work with Azure’s GCC-High environment. More information is available here.
Note: EAM was included in the D299 release and became fully available to Duo’s Federal Edition customers on October 3, 2024.
New “passport_assessment" field in Authentication Logs.
  • This field provides information on whether the authentication supported Duo Passport. It will return for all authentications, even if Duo Passport is not enabled. Authentication logs before August 2024 will not return this field.
End-of-Life Updates
End of Life and End of Support announcements
New and Updated Applications
Four new named applications with Duo Single Sign-On (SSO)
Duo Mobile for Android version 4.74.0 released
  • Miscellaneous bug fixes and behind-the-scenes improvements.
Duo Mobile for iOS version 4.74.0 released
Duo Desktop for macOS 6.13.1.0 beta released
  • Minor improvements and enhancements.
Duo Desktop for Windows 6.13.1 beta released
  • Fixed an issue that could cause the app to crash if an incoming request was prematurely terminated.
  • All temporary installer executables are now signed.
