04-16-2019 10:20 AM
I successfully deployed a test docker container based on the instructions from the lab Building an IOx Application with Docker
I then attempted to change the lab, to use ubuntu:18.04 as my base image rather than "alpine:3.5".
I was able to package, install, and activate the application. However, I received an error when trying to start the application:
Error while starting the app: ubuntutest, Cause: Failed to start container: Error: internal error: guest failed to start: /usr/libexec/libvirt_lxc: relocation error: /lib/x86_64-linux-gnu/libnss_dns.so.2: symbol __resolv_context_get, version GLIBC_PRIVATE not defined in file libc.so.6 with link time reference
I would like to know:
Code...
Dockerfile
FROM ubuntu:18.04
RUN apt -y update && \
apt -y install python3 \
python3-pip && pip3 install bottle
EXPOSE 8000
COPY main.py /main.py
CMD python3 /main.pymain.py
from bottle import route, run
from datetime import datetime
@route('/status/<device_id>')
def status(device_id):
return { "system": 1, "device": str(device_id) }
@route('/time')
def time():
current_time = datetime.now().isoformat(' ')
return {"system": 1, "datetime": current_time}
run(host='0.0.0.0', port=8000)package.yaml
descriptor-schema-version: "2.2"
info:
description: "IOx Docker Python Web Learning Lab Application"
version: "1.0"
author-link: "http://www.cisco.com"
author-name: "Cisco Systems"
app:
cpuarch: "x86_64"
type: docker
resources:
profile: c1.small
network:
interface-name: eth0
ports:
tcp:
- 8000
startup:
rootfs: rootfs.tar
target: ["python3 main.py"]activation.json
"resources": {
"profile": "c1.small",
"network": [{
"interface-name": "eth0",
"network-name": "iox-nat0",
"port_map": {
"mode": "auto",
"tcp": {
"8000": "8000"
04-16-2019 01:06 PM
Thanks for reporting this issue. Will get back to you on this soon.
Is there any reason you specifically need 18.04 Ubuntu base image ? We did verify with 16.04 Ubuntu rootfs and it works fine.
04-16-2019 01:25 PM
Thanks for the prompt reply.
Ubuntu 16.04 is perfectly fine. I will continue my testing using 16.04.
07-29-2019 11:44 PM
I have the same problem while trying to run an image which is built on 18.04. However, I can't use 16.04. Do you know when will 18.04 be supported by iox.
Best regards,
Gabrijel
07-30-2019 12:26 AM
Which iox platform are you planning to run ubuntu 18.04 container?
We are not seeing this issue in IR829.
07-30-2019 12:56 AM
@suressan I tried to deploy it in the iox sandbox lab, running the iox version 1.7.0.7.
However, I am currently working with IR809. My plan was to deploy it there as well.
07-30-2019 07:25 AM
08-02-2019 03:55 AM
I uploaded a docker application with Ubuntu 18.04 and its seems to be running fine. Any change regarding the sandbox issue?
Cheers,
G.
08-02-2019 08:47 AM
We will be publishing new version of sandbox where this is issue would be addressed. Will let you know the timeline on new sandbox version soon.
