How can I install Node.js on CGR1120?
luknagy
Community Member
I would like to deploy application on CGR 1120 ( anthonyray/IoE · GitHub ), but I am struggling with installing dependencies. I was successful with transferring source code of Node.js into GOS, however I wasn't able to install it (via make, dependencies missing in Python).Should those packages by compiled directly in GOS? Or is it possible to get some dev tools in GOS (Yocto Linux), like gcc ?
Thank you for any suggestions.
Steve Zhang
Hi Lucas,
Cisco does not provide cross-compiling tools for the Yocto Linux environment. The Yocto Linux GOS we provide is a 32-bit x86 Linux with kernel 3.8 and standard libraries. Any 32-bit binary compiled on a similar Linux version should work on Yocto. Please try to compile the applications before you upload applications and libraries to CGR GOS.
Steve
Steve Zhang
Hi Lucas,
Steve
chandlerheath
Visitor
I was successful installing pre-compiled binaries from tar file in the /software volume. There was some configuration that needed to be done however once it is in place, I used npm to install everything needed.
