03-20-2017 06:36 PM
is there a way to tell a docker container to use a serial device in the IR829?
I know that a typical Docker container can be granted serial device access with "docker run --device=/dev/ttyS3 ..."
But how do I tell to the ioxclient/local manager to grant serial device access to a package?
07-18-2017 10:13 PM
You need to set the serial port in the file of package.yaml. Please refer to Cisco DevNet: IOx - Docs (go to Python Application Using Serial Port as an example for using serial port)
07-29-2020 01:35 AM
Cisco DevNet: IOx - Docs, in this link we can see the examples for creating docker files, Yaml and container, but we couldn't found any serial port example with Yaml,
we are getting following error for the python example link provided
Is there any serial port example for docker container with Yaml file
07-30-2020 05:31 AM
Hello Rama -- Here is one such example:
https://github.com/etychon/iox-ir1101-serial-port/blob/master/package.yaml
