IR1101 Application Hosting: Session connect is not supported
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-14-2020 03:29 AM
Hi, everyone.
Through minor adaptations in the Cisco roadmap for the demo application, I can generate, deploy, activate and run the my own application (with id SGG) on the IR-1101. As can be seen below through the response to the 'show app-hosting detail' command, the IR-1101 considers that the SGG application is running.
But executing the command 'app-hosting connect appid SGG session' returns the message 'Session connect is not supported'. This is a different behavior from the demonstration application, where the command works and I have access to the demo application console.
Is there anything, beyond what is described in the tutorial, that should be configured in the IR1101, or in the package descriptor file, to enable access to the SGG application console?
Router#show app-hosting detail
App id : SGG
Owner : ioxui
State : RUNNING
Application
Type : docker
Version : 1.0
Description : Smart Grid Gateway
Path :
Activated profile name : c1.tiny
Resource reservation
Memory : 32 MB
Disk : 10 MB
CPU : 100 units
Attached devices
Type Name Alias
serial/shell iox_console_shell serial0
serial/aux iox_console_aux serial1
serial/syslog iox_syslog serial2
serial/trace iox_trace serial3
Network interfaces
eth0:
MAC address : 52:54:dd:a8:f9:d1
Router#app-hosting connect appid SGG session
Thanks in advance.
Andre Chrcanovic
- Labels:
IOx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-17-2021 12:17 AM - edited 02-17-2021 12:17 AM
my problem was very similar and I solved it by doing these four things:
1) Uninstall EI agent.
2) Enable app signature validation (I guess this is the critical step, since the app needs to access the secure storage network, i really don't know, maybe someone can shed some light - @Emmanuel Tychon?) IOx -> System setting -> Application Signature Validation
3) Configure DHCP for address assignment
4) Reinstall EI app
Hope this helps.
Best regards
Silla
