LXC installation leaves image files
huntc
Level 4
Level 4
When installing my LXC app on IOx I receive the following message:
"description": "Invalid Archive file: [Errno 28] No space left on device",
"errorcode": -1,
"message": "Invalid Archive file"
This got me wondering whether old images are being retained on the file system. I believe they are. If I issue:
du -h /software/caf/work/layers
...then this shows that 472M used.
At this point, I have no app installed, so this must be old LXC image layer info.
Can you please advise on a supported means of tidying up the disk?
Thanks.
So you’re suggesting that CAF performs no housekeeping on images and one must reformat the drive periodically?
