Mosquitto IPK package
azelenki
Hi, guys
Can someone help me to create the Mosquitto broker package (IPK), that I could install on the IR8X9 using "opkg"?
I have an EFM IoX package running on the IR809 and I want to make Mosquitto broker a part of this package.
BR,
Alexey
Steve Zhang
EFM IOx app package is an LXC container style app. To add Mosquitto broker, you may try to copy the related Mosquitto executables and config files to the specific folders of LXC container. Or, MQTT DSLink also provide a simple MQTT Broker, you may simply enable the port number of 1883, install the DSLink, enable the option of MQTT Broker at MQTT DSLink, and so that the MQTT Broker could be served accordingly.
hgovind
pre-built MQTT python library 'python-paho-mqtt' is available on the devhub. You can install this module using the opkg tool 'opkg install python-paho-mqtt'
