02-10-2021 09:21 AM
Just as described. It happens irregardless of browser used (also happens when using the CLI).
Happens with custom apps or Cisco ones (Edge Intelligence).
It's incredibly annoying.
Am I the only one with this problem?
Best regards
Silla Rizzoli
Solved! Go to Solution.
02-11-2021 06:02 AM - edited 02-11-2021 06:05 AM
The is the default behaviour for Docker-based platforms running IOS-XE.
To avoid this to happen: during activation uncheck the option "auto delete container instance" in "Advanced Settings" (see below).
Emmanuel
02-10-2021 01:20 PM
FYI: I used the Cisco Bug Search tool and didn't find any known bugs which match this description for the IR1101
Emmanuel
02-11-2021 07:44 AM
You are absolutely right, as always!
Thank you Emmanuel!
