Unable to start CAF on freshly installed IR809
radu.pintilie
Hi there,
I have some problems adding a new IR809 into FogDirectory. It was freshly installed with the bundle named ir800-universalk9-bundle.SPA.156-3.M2.bin ( IOX: Cisco-GOS,version-1.3.2.3 , IOS: version 15.6 )
As I've searched until now, it looks like the CAF hosting framework is not running in IOX.
I have a NAT rule for IOX like this: ip nat inside source static 192.168.2.2 10.10.30.181 (this exposes all the IOX ports on 10.10.30.181) so it does not look like a routing problem.
If I try to access the local manager (on https://10.10.30.181:8443/ ) I get a connection refused in browser.
The output from monit summary looks like this (and it looks like caf process is not available):
IR800-GOS-1:/software/caf# monit summary
Cannot translate 'IR800-GOS-1' to FQDN name -- Temporary failure in name resolution
The Monit daemon 5.14 uptime: 3d 19h 51m
Process 'dmo'                       Running
File 'product_id'                   Accessible
File 'hwid'                         Accessible
File 'svcbr0'                       Accessible
File 'ioxcaps'                      Accessible
Process 'caf'                       Not monitored
File 'cgroup'                       Not monitored
System 'qemux86-64'                 Running
Do you know if there are solutions to this problem?
Thank you,
Radu
Steve Zhang
From the information you listed, the CAF (IOX Framework) is not started successfully. That's the reason you could not access the Local Manager.
You may re-install the GOS with a new GOS image from CCO with the below commands.
IR800# copy scp://userid@scpServerIp//ir829/ir800-ioxvm-1.x.x.x.bin flash:
IR800# guest-os 1 stop
IR800# guest-os 1 image uninstall
IR800# guest-os 1 image install flash:ir800-ioxvm-1.x.x.x.bin verify
IR800# guest-os 1 start
It is also possible to install the Guess OS image from the bundle with the option of "exclude HV-IOS". For example: "bundle install flash:ir800-universalk9-bundle.SPA.15x-x.xx.bin exclude HV-IOS".
Hi Steve,
Thank you for answer.
I've managed to solve the problem by changing the file /software/caf/work/product_id as described in 15-6-3M2-Release-Notes (Cisco IOS Release 15.6(3)M2 - Release Notes for Cisco IR800 Industrial Integrated Services Routers and Cisco 1000 Series…).
Best regards,
Radu Pintilie
