Value of <mirror location> for SDK apps README
nathan
Level 4
Level 4
The instructions in the tutorials/apps README say:
"4.4) Create a Yocto Project
vm:~/projects/release/sdk-1>iox ldsp execute yocto-1.7 project create -p ../sample_project -t isr800-qemu -m <mirror location> -x"
Where "<mirror location>" seems not to be explained, but this is what I did, starting in a suitable working directory:
mkdir projects
cd projects
mkdir mirror
iox ldsp execute yocto-1.7 project create -p sample_project -t isr800-qemu -m mirror -x
Mirrors set to '/mnt/hgfs/IOX/iox-sdk-1.0.0.0/projects/mirror'
'No network' flags enabled
Project created successfully at '/mnt/hgfs/IOX/iox-sdk-1.0.0.0/sample_project'
So, that seemed to achieve what was required at this stage.
Nathan
Alexander Stevenson
Thank you
