ESA Contents FIlter: Defang Rule not work
a.zahid
I have a defang rule for incoming email in Cisco cESA (as per screenshot, just example). There are times when incoming email hit default policy, the defang rule will take action and defang the URL inside the email even though the domain of sender is set to bypass (@hd.onmicrosoft.com).
I still think my configuration is correct but just in case, can anyone give their insight on this, or any suggestion to make the rule not intermittent?
Thanks.
ppreenja
For your requirement, I would suggest that instead of creating the filter, you can create a new policy for the particular domain (hd.onmicrosoft.com).
From the example filter shared, I can see that you are using mail-from header not equal to check which allow emails with a different "mail-from" header and "from" headers and hence it might bypass. Examples any email with mail-from header value as "abc@imposter.com" and from the header as "xyz@hd.onmicrosoft.com" will match this filter.
When you define a domain incoming mail policy, it will match the below three headers:
1) Mail-From
2) From
3) Reply-To
User matches are evaluated as a top-down fashion, first match wins.
Please check below article for more details:
https://www.cisco.com/c/en/us/support/docs/security/cloud-email-security/212808-configure-flexible-mail-policy-match-fea.html
I hope the above information helps.
Cheers,
Pratham
