Multiple incoming listener for Cisco ESA
jperez netics
hi, i was looking for some information about the Cisco ESA behavior if i configure two listeners with different interfaces but both for incoming connections and to the same domain
The case is, the customer is migrating from Data Center and is requesting a soft migration, where we configure the new listener from the new data Center while keeping the old connection (yes, appliances in both DC are connected in this moment)
is it possible to create two listeners and receive connections from outside with no issues?
i was planning to replicate the HAT and RAT table to the new interface and create the second listener with DATA2 interface
i think that the model is not important but in case, it is a C390
Yep, the ESA doesnt care. Set up as many as you need.
