power specs for a c360
pjordan
I'm putting a C360 in Terremark facility and need to now how much power it consumes.  Where are the power specs for a c360?
Robert Sherwin
C360 - hardware specs --->
MTBF: 78,800 hours
Fan Exhaust Volume: 43.5cfm
Ambient Noise: 68.9db
System Heat/Power (watts): 260.4
Total Current (amps): 1.25
Air Temp Rise (F): 19.3
Weight (lbs): 49
Hope this helps!
-Robert
(*If you have received the answer to your original question, and found this helpful/correct - please mark the question as answered, and be sure to leave a rating to reflect!)
Its a Dell box... get the serial number and look it up there...
Robert Sherwin
MTBF: 78,800 hours
Weight (lbs): 49
Hope this helps!
-Robert
