11-17-2022 12:29 AM
Dear all,
I plan to upgrade a lot of machines and, even if I'm going to do it slowly, I wanted to know if anyone already deployed new connector version 8.1.3 in a significant number of machines and saw any error during normal execution.
I'll be very gratefull if someone tell me the experience before I upgrade.
Thanks in advance.
11-22-2022 05:17 PM
We are also planning to upgrade to 8.1.3. Hoping anyone who already started or completed the upgrade to this version can share their experience, challenges or issues encountered during the process.
12-01-2022 11:25 AM
25% of mine are failing. The Machine are running Windows 10 .
I am getting error code 16019. - Unable to verify Secure Endpoint's digital signature. Please update Windows.
What Updates / Version is supported.
12-02-2022 07:55 AM
Hi, check release notes. Here you'll found the required KB for each OS version. With the right KB installed, agent upgrade without problem.
12-02-2022 07:36 AM
Small pilot project 15% of W10 systems are failing
Upgrade from 8.0.1 to 8.1.3.
Same error code 16019. - Unable to verify Secure Endpoint's digital signature. Please update Windows.
12-22-2022 08:34 AM
Hi All,
Prior to upgrading your connectors, I would strongly suggest checking if your OS is compatible with the 8.1.3 versions.
Please refer to the below article for the same:
Also, please refer to the below release notes for more details:
https://docs.amp.cisco.com/Release%20Notes.pdf
I hope the above helps!
Cheers,
Pratham
03-30-2023 08:21 AM - edited 03-30-2023 11:11 AM
In my experience, 8.1.3 installs after monthly update KB5005611 preview (9/30/2021) in windows 10 21h1, ubr 1266. windows 10 21h2 works out of the box, ubr 1288, 10/16/2021. Windows 11 21H2 out of the box (ubr 194) works. So as long as windows update is up to 10/2021.
