how do I create a custom node ?
Rush1
Connect - Parmar
Test reply
Connect - Subbu
Hi Rush1,
Thanks for writing to us.
Customnode is a powerful feature of IMIconnect platform - that helps in integrating with any thirdparty APIs (restful or Webservice based) - and in addition will generate a node - that can be used as part of workflows.
For more detailed information please refer to the link below.
https://help.imiconnect.io/docs/custom-nodes
WebexOne Team.
Connect - Tanuj
Please follow this guide to configure a custom integration using custom node: https://help.imiconnect.io/docs/custom-nodes
Hope this helps!
Tanuj Goyal
Webex Connect
