Findit hosts inventory
jamaye
Hi folks !
Is it possible in FindIT to add manually the informations relative to the hosts in the inventory ?
Thank you for your help, have a good day !
Jimmy.
It's definitely something we will look at.  There are good reasons to enable the static configuration of these and a few other parameters.  I can't make any promises right now though.
Cheers,
Dave.
David Harper
I'm afraid this is not currently possible.  If we were to add this capability, what information would you want to update?
Dave.
Hi David,
Thank you for your reply. It would be great if we can have the hostname and the IP address for the hosts, like in UNMS controler for example, even if we have to custom those field manually.
Is it a feature that it could be avalaible in the future ?
Cheers,
Dave.
