CISCO Findit Login
diogo_sampaio
Good morning,
What are my OS credentials to log in cisco FindIt.
When you installed Windows in the first place, did you set it to log you in automatically?  If so, you probably don't have a password set.  You should be able to set a password using Settings > Accounts > Sign-in Options and temporarily turn on signing in.  At that point, you can finish the FindIT installation process, and then use the same settings page to go back to have Windows automatically log you in.
Cheers,
Dave.
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
I think you are talking about the FindIT utility. FindIT requests your OS login credentials.
It is the account on the computer. For example Windows 7 username and password to use Cisco FindIT. ( in case that you are using Windows 7 for example)
This is for security reasons as Cisco FindIT can provide a great deal of information about your network.
Please rate this post or marked as answered to help other Cisco customers.
 Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Where can I know, in Windows 10 my OS credentials?
Cheers,
Dave.
