Using DMZ to connect to internet
Trond Husoe
I am having problems accessing the internet when changing route from using outside to DMZ to access the internet. Reason for this change is because I have a FTP-server in DMZ that also needs access to the internet through DMZ.
The main server has two NICs and so I am routing default gw through the inside. I have tried to change default gateway to the DMZ-nic, but then I loose connection to the internet...
The ftp-server is a virtual maching running on the main server.
I have attached two nics to the FTP-server, but I can remove the last one.
I have a base license.
The configuration is as following:
# show run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
domain-name inside-sport.no
enable password XXXXXXXXXXXXXXXXX encrypted
passwd XXXXXXXXXXXXXXXXX encrypted
names
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 12
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp
interface Vlan12
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 192.168.2.1 255.255.255.0
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns domain-lookup outside
dns domain-lookup DMZ
dns server-group DefaultDNS
name-server 193.75.75.75
name-server 192.168.1.11
name-server 192.168.1.12
name-server 193.75.75.193
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network inside-net
subnet 192.168.1.0 255.255.255.0
object network NETWORK_OBJ_10.10.10.0_28
subnet 10.10.10.0 255.255.255.240
object network NETWORK_OBJ_192.168.1.128_27
subnet 192.168.1.128 255.255.255.224
object network NETWORK_OBJ_192.168.1.0_24
object network NETWORK_OBJ_192.168.254.0_28
subnet 192.168.254.0 255.255.255.240
object network dmz-ftpserver
host 192.168.2.101
description FTP server Host Object
object network dmz-webserver
host 192.168.2.100
description Web Server Host Object
object network ftp-server
object service FTP
service tcp source eq ftp
object service WWW
service tcp source eq www
object network DMZ.net
subnet 192.168.2.0 255.255.255.0
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network NET-VPNPOOL
network-object 173.194.32.34 255.255.255.0
access-list outside_access_in extended permit tcp any host 192.168.2.101 eq ftp
access-list outside_access_in extended permit tcp any host 192.168.2.100 eq www
access-list VPN-INSIDE-SPORT_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list inside_access_dmz extended permit tcp any object DMZ.net range 1 65535
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
ip local pool VPN-Pool 192.168.254.1-192.168.254.10 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (DMZ,outside) source static dmz-webserver interface service WWW WWW
nat (DMZ,outside) source static dmz-ftpserver interface service FTP FTP
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.10.10.0_28 NETWORK_OBJ_10.10.10.0_28 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_192.168.1.128_27 NETWORK_OBJ_192.168.1.128_27 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static NETWORK_OBJ_192.168.254.0_28 NETWORK_OBJ_192.168.254.0_28 no-proxy-arp route-lookup
nat (outside,outside) source dynamic NET-VPNPOOL interface
nat (inside,outside) dynamic interface
nat (DMZ,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_access_dmz in interface DMZ
route outside 0.0.0.0 0.0.0.0 173.194.32.34 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
aaa authorization exec authentication-server
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.1.1 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 30
console timeout 0
management-access inside
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
dhcpd domain inside-sport.no
dhcpd auto_config outside
dhcpd address 192.168.1.20-192.168.1.49 inside
dhcpd dns 192.168.1.11 192.168.1.12 interface inside
dhcpd domain inside-sport.no interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy VPN-INSIDE-SPORT internal
group-policy VPN-INSIDE-SPORT attributes
dns-server value 192.168.1.11 193.75.75.193
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN-INSIDE-SPORT_splitTunnelAcl
default-domain value inside-sport.no
username foo password XXXXXXXXXXXXXXXXX encrypted privilege 15
tunnel-group VPN-INSIDE-SPORT type remote-access
tunnel-group VPN-INSIDE-SPORT general-attributes
address-pool VPN-Pool
default-group-policy VPN-INSIDE-SPORT
tunnel-group VPN-INSIDE-SPORT ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:d0c94dce38e18ab6599ca05d641e8932
: end
ciscoasa(config)#
When running:
packet-tracer input DMZ icmp 172.16.4.51 8 0 4.2.2.2
I get this output:
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: DMZ
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Route table on server connected to the inside:
# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
192.168.254.0   192.168.1.1     255.255.255.0   UG    0      0        0 eth0
192.168.2.0     0.0.0.0         255.255.254.0   U     0      0        0 eth1
0.0.0.0         192.168.2.1     0.0.0.0         UG    0      0        0 eth1
Route table for FTP-server in DMZ:
route -n
192.168.2.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth1
0.0.0.0         192.168.2.1     0.0.0.0         UG    0      0        0 eth0
Jennifer Halim
A few things that need to be modified:
1) When running packet tracer, the source address must be your DMZ server IP (192.168.2.101), instead of 172.16.4.51.
2) To try ping, you would also need to configure icmp inspection:
   inspect icmp
3) If you only need outbound connection to the internet from your ftp server, then you can remove this:
no nat (DMZ,outside) source static dmz-ftpserver interface service FTP FTP
Then "clear xlate"
4) This access-list is incorrect, looks like you applied that to the inside interface before, so if you are applying it to DMZ, it needs to change.
You can remove that access-list from the DMZ interface and you should be able to access the internet because if you don't need to restrict access from DMZ to internet, you don't have to configure any access-list:
no access-group inside_access_dmz in interface DMZ
1) Changed the IP address (what a Noob I am) to 192.168.2.101:
packet-tracer input DMZ icmp 192.168.2.101 8 0 4.2.2.2
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
2) OK - I'll consider that
3) All virtual servers (I believe there are 5 virtual linux servers or so in inside zone) need internet access + any laptops (currently three) that are in the network as well. So all machines in inside + dmz shall have outside access. In DMZ I have an FTP and a Web-server.
The www and the ftp would need to send in and out, right?
4) OK. I'll remove that one and report back.
3) Do they need inbound access? ie: does user from the internet needs to FTP or web access your server?
