ASA 5505 Configuration Issues
bettston1
I have been given the task of configuring an ASA 5505 from scratch and been wrestling unsuccesfully with it now for over a week.  The scenario is 3 vlans outside, inside and dmz. dmz has one fixed ip server (at the moment)
what i need to get to is:
outside -> dmz webserver
inside -> no access to outside
inside  -> access to dmz webserver with  rdp and ping
Here is the current no working config, intersingly rdp gets a response but thats all. I deally i would like to do all setup through asdm 6.3 but any ting that help, even a complete teardown would be great
Tony
interface Vlan1
 no forward interface Vlan2
 nameif inside
 security-level 100
 ip address 160.100.30.253 255.255.252.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 172.16.0.253 255.255.255.0
interface Vlan3
 nameif dmz
 security-level 50
 ip address 11.0.200.253 255.255.255.0
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
 switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network Dmztrans
 host 160.100.31.145
object network dmzhost
 host 11.0.200.145
 description DMZ Host Machine
object network PublicServer_NAT1
 host 11.0.200.145
object network network1
 subnet 11.0.200.0 255.255.255.0
object network inside-network
 subnet 160.100.30.0 255.255.255.0
object network inside-network2
object network dmz
object-group service RDP tcp
 port-object eq 3389
object-group network DM_INLINE_NETWORK_1
 network-object object Dmztrans
 network-object object dmzhost
access-list dmz_access_in extended permit tcp any object Dmztrans object-group RDP
access-list inside_access extended permit tcp any host 11.0.200.145 object-group RDP
access-list inside_access extended permit icmp any host 11.0.200.145 echo-reply
access-list inside-in extended permit icmp 11.0.200.0 255.255.255.0 any
access-list outside-in extended permit icmp any any echo-reply
access-list global_access extended permit tcp object-group DM_INLINE_NETWORK_1 object Dmztrans object-group RDP
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (dmz,inside) source static dmzhost dmzhost destination static Dmztrans Dmztrans
nat (inside,dmz) source static inside-network inside-network destination static dmz dmz
 nat (inside,outside) dynamic interface
 nat (dmz,inside) static Dmztrans
 nat (dmz,inside) dynamic interface
access-group inside_access in interface inside
access-group dmz_access_in in interface dmz
access-group global_access global
route inside 0.0.0.0 0.0.0.0 160.100.30.253 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 160.100.28.0 255.255.252.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 11.0.200.0 255.255.255.0 dmz
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 160.100.31.1-160.100.31.32 inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
stevechege
Hello, It could be a license issue.
If you can SSH into the device, try and do a show version as shown below.
or through the ASDM
Configuration > Device Management > Licensing >
ASA-PLUS# show version
For security plus License
~ out-put~
Licensed features for this platform:
Maximum Physical Interfaces       : 8              perpetual
VLANs                             :
20             DMZ Unrestricted
Dual ISPs                         : Enabled        perpetual
VLAN Trunk Ports                  : 8              perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Standby perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 25             perpetual
Total VPN Peers                   : 25             perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
Cluster                           : Disabled       perpetual
This platform has an ASA 5505 Security Plus license.
ASA-BASE# show version
For Base License
~ out-put~
VLANs                          : 3              DMZ Restricted
Dual ISPs                      : Disabled       perpetual
VLAN Trunk Ports               : 0              perpetual
Inside Hosts                   : 50             perpetual
Failover                       : Disabled       perpetual
VPN-DES                        : Enabled        perpetual
VPN-3DES-AES                   : Enabled        perpetual
SSL VPN Peers                  : 2              perpetual
Total VPN Peers                : 10             perpetual
This platform has a Base license.
If it says 3 DMZ restricted. That could be your problem.
The inside <==> DMZ might not be able to talk to each other.
"The Base license restricts you to three(3) VLAN's, with the third VLAN only being able to initiate communicate with one of the other two."
Source.
http://security.stackexchange.com/questions/57045/asa5505-dmz-issue
